Hello, I’m trying to setup zigbee2mqtt, with mosquitto (and obviously HA)
I’m new to HA and have watched a few tutorial videos and browsed the forum on this exact issue.
Zigbee2mqtt doesnt allow me to register my devices somehow. It doesn’t give an error, and just says this:
[13:15:46] INFO: Preparing to start...
[13:15:46] INFO: Socat not enabled
[13:15:48] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-09-17 13:15:54: Logging to console and directory: '/config/zigbee2mqtt/log/2023-09-17.13-15-54' filename: log.txt
Zigbee2MQTT:info 2023-09-17 13:15:54: Starting Zigbee2MQTT version 1.33.0 (commit #unknown)
Zigbee2MQTT:info 2023-09-17 13:15:54: Starting zigbee-herdsman (0.18.5)
Zigbee2MQTT:info 2023-09-17 13:15:54: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-09-17 13:15:54: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":88,"product":0,"revision":"0x26580700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:info 2023-09-17 13:15:54: Currently 0 devices are joined:
Zigbee2MQTT:info 2023-09-17 13:15:54: Zigbee: disabling joining new devices.
Zigbee2MQTT:error 2023-09-17 13:16:54: Failed to set permit join to false
Zigbee2MQTT:info 2023-09-17 13:16:54: Connecting to MQTT server at mqtt://core-mosquitto
Zigbee2MQTT:info 2023-09-17 13:16:55: Connected to MQTT server
Zigbee2MQTT:info 2023-09-17 13:16:55: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-09-17 13:16:55: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2023-09-17 13:16:55: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":88,"product":0,"revision":"0x26580700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x6eaacbd84d255ebf","panID":16010},"permit_join":false,"version":"1.33.0"}'
Zigbee2MQTT:info 2023-09-17 13:16:55: Zigbee2MQTT started!
Zigbee2MQTT:info 2023-09-17 13:17:17: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-09-17 13:17:20: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-09-17 13:17:30: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-09-17 13:17:56: Successfully changed options
Zigbee2MQTT:info 2023-09-17 13:17:56: MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":true},"status":"ok","transaction":"7f1q8-4"}'
Zigbee2MQTT:info 2023-09-17 13:18:02: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-09-17 13:18:02: Successfully changed options
Zigbee2MQTT:info 2023-09-17 13:18:02: MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":true},"status":"ok","transaction":"7f1q8-5"}'
Zigbee2MQTT:error 2023-09-17 13:18:04: Request 'zigbee2mqtt/bridge/request/options' failed with error: 'homeassistant must be boolean'
Zigbee2MQTT:info 2023-09-17 13:18:05: MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{},"error":"homeassistant must be boolean","status":"error","transaction":"7f1q8-6"}'
Zigbee2MQTT:info 2023-09-17 13:18:05: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-09-17 13:18:05: Successfully changed options
Zigbee2MQTT:info 2023-09-17 13:18:05: MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":true},"status":"ok","transaction":"7f1q8-7"}'
/config/zigbee2mqtt/configuration.yaml:
homeassistant: true
advanced:
network_key:
- 64
- 89
- 217
- 156
- 228
- 43
- 92
- 180
- 46
- 254
- 103
- 110
- 175
- 239
- 77
- 106
pan_id: 16010
ext_pan_id:
- 110
- 170
- 203
- 216
- 77
- 37
- 94
- 191
mqtt:
server: mqtt://core-mosquitto:1883
user: homeassistant
password: AutomaticHomeAssitantPassword (Same password as at mqtt)
frontend:
port: 8099
Zigbee2mqtt add-on config:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
serial:
port: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2228585-if00
adapter: deconz
zigbee_herdsman_debug: false
MQTT (mosquitto) settings:
broker: core-mosquitto
port: 1883
username: homeassistant
password: AutomaticHomeAssitantPassword (Same password as at zigbee2mqtt)
USB port/hardware:
