I would like zigbee2mqtt to be native to home assistant. and that the device sonoff dongle - P and E connect without having to make numerous configurations.
That’s not going to happen.
- Home Assistant already has ZHA built in
- Zigbee2MQTT is developed by somebody else
- Zigbee2MQTT is designed and intended to integrate with a range of platforms
As Z2M uses MQTT Discovery the number of configuration steps required are already as low as they can get - particularly if you’re using the add-on.
