Running HA (dockers) on 451 QNAP .
SONOFF Dongle Plus ZBDongle-E
installed on /dev/ttyACM0.
I did manage to make it work using ZHA(took hoursss to understand how).
the problem :
as understand , koenkk firmware support only ZBDongle-P version .
does it mean ZBDongle-E can or can’t work with zigbee2mqtt (docker)?
I tried but getting error:
Zigbee2MQTT:info 2022-11-05 01:30:19: Starting Zigbee2MQTT version 1.28.1 (commit #48117fd)
Zigbee2MQTT:info 2022-11-05 01:30:19: Starting zigbee-herdsman (0.14.68)
Zigbee2MQTT:debug 2022-11-05 01:30:20: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyACM0"}}'
Zigbee2MQTT:error 2022-11-05 01:30:41: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-11-05 01:30:41: Failed to start zigbee
Zigbee2MQTT:error 2022-11-05 01:30:41: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-11-05 01:30:41: Exiting...
Zigbee2MQTT:error 2022-11-05 01:30:42: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:109:5)
compose:
zigbee2mqtt:
image: koenkk/zigbee2mqtt
container_name: zigbee2mqtt
environment:
- PUID=1000
- PGID=1000
- TZ=${TZ}
networks:
- inframain
hostname: zigbee2mqtt
depends_on:
- mosquitto
ports:
- '9250:8080'
volumes:
- ./Zigbee2MQTT/config:/app/data
- /run/udev:/run/udev:ro
devices:
- /dev/ttyACM0:/dev/ttyACM0
restart: unless-stopped
privileged: true
configuration.yaml
homeassistant: true
permit_join: true
# MQTT settings
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://192.168.1.113:1883'
# Serial settings
serial:
port: /dev/ttyACM0
