interesting is that I already had it working for quite some time until my SD card died. I’ve reinstalled fresh hassio on my rpi 3 B+ but this time on SSD. Everything works fine, just zigbee2mqtt is not detecting devices when I put them in pairing mode. Nothing happens. I used to see it in the log when the device was detected.
Any idea what could be wrong?
This is log from zigbee2mqtt (log_level: debug):
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
./run.sh: line 17: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2020-06-09T20:01:00: PM2 log: Launching in no daemon mode
2020-06-09T20:01:00: PM2 log: App [npm:0] starting in -fork mode-
2020-06-09T20:01:00: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.13.1
> node index.js
zigbee2mqtt:info 2020-06-09 20:01:05: Logging to console and directory: '/share/zigbee2mqtt/log/2020-06-09.20-01-05' filename: log.txt
zigbee2mqtt:debug 2020-06-09 20:01:05: Removing old log directory '/share/zigbee2mqtt/log/2020-06-08.23-05-02'
zigbee2mqtt:debug 2020-06-09 20:01:06: Loaded state from file /share/zigbee2mqtt/state.json
zigbee2mqtt:info 2020-06-09 20:01:06: Starting zigbee2mqtt version 1.13.1 (commit #unknown)
zigbee2mqtt:info 2020-06-09 20:01:06: Starting zigbee-herdsman...
zigbee2mqtt:debug 2020-06-09 20:01:06: Using zigbee-herdsman with settings: '{"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":"HIDDEN"},"databasePath":"/share/zigbee2mqtt/database.db","databaseBackupPath":"/share/zigbee2mqtt/database.db.backup","backupPath":"/share/zigbee2mqtt/coordinator_backup.json","serialPort":{"baudRate":115200,"rtscts":true,"path":"/dev/ttyACM0"},"adapter":{"concurrent":null}}'
zigbee2mqtt:info 2020-06-09 20:01:08: zigbee-herdsman started
zigbee2mqtt:info 2020-06-09 20:01:08: Coordinator firmware version: '{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}'
zigbee2mqtt:debug 2020-06-09 20:01:08: Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
zigbee2mqtt:info 2020-06-09 20:01:08: Currently 0 devices are joined:
zigbee2mqtt:warn 2020-06-09 20:01:08: `permit_join` set to `true` in configuration.yaml.
zigbee2mqtt:warn 2020-06-09 20:01:08: Allowing new devices to join.
zigbee2mqtt:warn 2020-06-09 20:01:08: Set `permit_join` to `false` once you joined all devices.
zigbee2mqtt:info 2020-06-09 20:01:08: Zigbee: allowing new devices to join.
zigbee2mqtt:info 2020-06-09 20:01:08: Connecting to MQTT server at mqtt://core-mosquitto
zigbee2mqtt:info 2020-06-09 20:01:08: Connected to MQTT server
zigbee2mqtt:info 2020-06-09 20:01:08: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info 2020-06-09 20:01:08: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.13.1","commit":"unknown","coordinator":{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}},"log_level":"debug","permit_join":true}'
