config from the addon page!!
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_32015794c019ec11924e77e5f01c6278-if00-port0
advanced:
log_level: warn
pan_id: 6754
channel: 13
network_key:
- 9
- 3
- 5
- 11
- 1
- 15
- 7
- 13
- 8
- 2
- 0
- 6
- 4
- 13
- 12
- 10
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
config from the samba share
(it generates it’s own password and user)
"external_converters": [],
"devices": [
"devices.yaml"
"groups": [
"groups.yaml"
"homeassistant": true,
"permit_join": false,
"mqtt": {
"base_topic": "zigbee2mqtt",
"user": "addons",
"password": "iT5kutieRohf7Oyo7Foh2yoht6lohco9poof6poCah2aqu5maaque7itheiv0eeb",
"server": "mqtt://core-mosquitto:1883"
"serial": {
"port": "/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_32015794c019ec11924e77e5f01c6278-if00-port0"
"advanced": {
"log_level": "warn",
"pan_id": 6754,
"channel": 13,
"network_key": [
9,
3,
5,
11,
1,
15,
7,
13,
8,
2,
0,
6,
4,
13,
12,
10
"availability_blocklist": [],
"availability_passlist": []
"device_options": {},
"blocklist": [],
"passlist": [],
"queue": {},
"frontend": {
"port": 8099
"experimental": {},
"availability": false
i have a user in Home Assistant called mqtt-user
i have tried adding
server: mqtt://192.168.30.4:1883
user: mqtt-user
password: xxxxxxxx
but then i get errors in the main log
