Just trying to get Sonoff dongle 3 P running without success.
Configuration
socat
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt
server: mqtt:core-mosquitto:1883
user: mqtt_user
password: ******
Serial
port: >-
/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
Log
[16:18:17] INFO: Preparing to start…
[16:18:17] INFO: Socat not enabled
[16:18:17] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-03-22 16:18:18: Logging to console and directory: ‘/config/zigbee2mqtt/log/2023-03-22.16-18-18’ filename: log.txt
Zigbee2MQTT:info 2023-03-22 16:18:18: Starting Zigbee2MQTT version 1.30.2 (commit #unknown)
Zigbee2MQTT:info 2023-03-22 16:18:19: Starting zigbee-herdsman (0.14.96)
Zigbee2MQTT:error 2023-03-22 16:18:39: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-03-22 16:18:39: Failed to start zigbee
Zigbee2MQTT:error 2023-03-22 16:18:39: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2023-03-22 16:18:39: Exiting…
Zigbee2MQTT:error 2023-03-22 16:18:39: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
any ideas on this please
Running HAOS on a PC that has Ubuntu installed - nothing else
