i have installed a sonoff USB 3.0 Dongle in a raspberry pi. I flashed with last coordinator firmware 2022/07. I set up in HA Mosquitto broker and zigbee2mqtt addon.
It seems run without error but i can not pair any device. Just can not find anithing
I tried to reflash and same result.
Do i miss something ?
Log is bellow:
Mosquitto
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[18:12:16] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[18:12:17] INFO: Starting NGINX for authentication handling…
[18:12:18] INFO: Starting mosquitto MQTT broker…
2022-12-01 18:12:18: Warning: Mosquitto should not be run as root/administrator.
[18:12:18] INFO: Successfully send discovery information to Home Assistant.
[18:12:18] INFO: Successfully send service information to the Supervisor.
2022-12-01 18:12:18: mosquitto version 2.0.11 starting
2022-12-01 18:12:18: Config loaded from /etc/mosquitto/mosquitto.conf.
2022-12-01 18:12:18: Loading plugin: /usr/share/mosquitto/go-auth.so
2022-12-01 18:12:18: ├── Username/password checking enabled.
2022-12-01 18:12:18: ├── TLS-PSK checking enabled.
2022-12-01 18:12:18: └── Extended authentication not enabled.
2022-12-01 18:12:18: Opening ipv4 listen socket on port 1883.
2022-12-01 18:12:18: Opening ipv6 listen socket on port 1883.
2022-12-01 18:12:18: Opening websockets listen socket on port 1884.
2022-12-01 18:12:18: mosquitto version 2.0.11 running
2022-12-01 18:12:18: New connection from 127.0.0.1:60382 on port 1883.
2022-12-01 18:12:18: Client closed its connection.
2022-12-01 18:12:24: New connection from 172.30.32.2:54968 on port 1883.
2022-12-01 18:12:24: Client closed its connection.
2022-12-01 18:13:58: New connection from 172.30.32.1:53911 on port 1883.
2022-12-01 18:13:58: New client connected from 172.30.32.1:53911 as 3Q5KfuBmOqTsqnHaTOARph (p2, c1, k60, u’homeassistant’).
2022-12-01 18:13:59: New connection from 172.30.33.1:51938 on port 1883.
2022-12-01 18:13:59: New client connected from 172.30.33.1:51938 as mqttjs_64fa5676 (p2, c1, k60, u’calin_mqtt’).
2022-12-01 18:14:24: New connection from 172.30.32.2:33916 on port 1883.
2022-12-01 18:14:24: Client closed its connection.
2022-12-01 18:16:24: New connection from 172.30.32.2:38380 on port 1883.
2022-12-01 18:16:24: Client closed its connection.
2022-12-01 18:18:24: New connection from 172.30.32.2:39024 on port 1883.
2022-12-01 18:18:24: Client closed its connection.
2022-12-01 18:19:06: New connection from 172.30.32.1:38467 on port 1883.
2022-12-01 18:19:06: New client connected from 172.30.32.1:38467 as 6GLbHKygvNk3ySSbhhhk2p (p2, c1, k60, u’homeassistant’).
2022-12-01 18:19:06: Client 6GLbHKygvNk3ySSbhhhk2p disconnected.
2022-12-01 18:19:16: New connection from 172.30.32.1:52277 on port 1883.
2022-12-01 18:19:16: New client connected from 172.30.32.1:52277 as 2zRys3r5SZcc57mzndPH18 (p2, c1, k60, u’homeassistant’).
2022-12-01 18:19:29: New connection from 172.30.32.1:39767 on port 1883.
2022-12-01 18:19:29: New client connected from 172.30.32.1:39767 as 7p8lcwIM5em4i7DBFOauCW (p2, c1, k60, u’homeassistant’).
2022-12-01 18:20:24: New connection from 172.30.32.2:54384 on port 1883.
2022-12-01 18:20:24: Client closed its connection.
2022-12-01 18:20:47: Client 3Q5KfuBmOqTsqnHaTOARph has exceeded timeout, disconnecting.
2022-12-01 18:20:59: Client 2zRys3r5SZcc57mzndPH18 has exceeded timeout, disconnecting.
2022-12-01 18:22:24: New connection from 172.30.32.2:45614 on port 1883.
2022-12-01 18:22:24: Client closed its connection.
2022-12-01 18:24:24: New connection from 172.30.32.2:36362 on port 1883.
2022-12-01 18:24:24: Client closed its connection.
2022-12-01 18:26:24: New connection from 172.30.32.2:56314 on port 1883.
2022-12-01 18:26:24: Client closed its connection.
2022-12-01 18:28:24: New connection from 172.30.32.2:49818 on port 1883.
2022-12-01 18:28:24: Client closed its connection.
2022-12-01 18:30:24: New connection from 172.30.32.2:47454 on port 1883.
2022-12-01 18:30:24: Client closed its connection.
2022-12-01 18:32:24: New connection from 172.30.32.2:45914 on port 1883.
2022-12-01 18:32:24: Client closed its connection.
2022-12-01 18:34:24: New connection from 172.30.32.2:37860 on port 1883.
2022-12-01 18:34:24: Client closed its connection.
2022-12-01 18:36:24: New connection from 172.30.32.2:48446 on port 1883.
2022-12-01 18:36:24: Client closed its connection.
2022-12-01 18:38:24: New connection from 172.30.32.2:39018 on port 1883.
2022-12-01 18:38:24: Client closed its connection.
2022-12-01 18:40:24: New connection from 172.30.32.2:39178 on port 1883.
2022-12-01 18:40:24: Client closed its connection.
2022-12-01 18:42:18: Saving in-memory database to /data//mosquitto.db.
Zigbee2MQTT
[18:13:49] INFO: Preparing to start…
[18:13:49] INFO: Socat not enabled
[18:13:51] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2022-12-01 18:13:55: Logging to console and directory: ‘/config/zigbee2mqtt/log/2022-12-01.18-13-55’ filename: log.txt
Zigbee2MQTT:info 2022-12-01 18:13:55: Starting Zigbee2MQTT version 1.28.2 (commit #unknown)
Zigbee2MQTT:info 2022-12-01 18:13:55: Starting zigbee-herdsman (0.14.68)
Zigbee2MQTT:info 2022-12-01 18:13:59: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2022-12-01 18:13:59: Coordinator firmware version: ‘{“meta”:{“maintrel”:1,“majorrel”:2,“minorrel”:7,“product”:1,“revision”:20220219,“transportrev”:2},“type”:“zStack3x0”}’
Zigbee2MQTT:info 2022-12-01 18:13:59: Currently 0 devices are joined:
Zigbee2MQTT:warn 2022-12-01 18:13:59: permit_join
set to true
in configuration.yaml.
Zigbee2MQTT:warn 2022-12-01 18:13:59: Allowing new devices to join.
Zigbee2MQTT:warn 2022-12-01 18:13:59: Set permit_join
to false
once you joined all devices.
Zigbee2MQTT:info 2022-12-01 18:13:59: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2022-12-01 18:13:59: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2022-12-01 18:13:59: Connected to MQTT server
Zigbee2MQTT:info 2022-12-01 18:13:59: MQTT publish: topic ‘zigbee2mqtt/bridge/state’, payload ‘{“state”:“online”}’
Zigbee2MQTT:info 2022-12-01 18:13:59: Started frontend on port 0.0.0.0:8099
Any sugestion ?
What means:
Is a device tring to connect or is something different ?
