Zigbee2MQTT not starting after update to 2.0.0
@trash.heap: I installed the 2.0. and set the legacy_action_sensor to true. Here is my configuration.yaml. This works fine:
homeassistant:
  enabled: true
  legacy_action_sensor: true
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://mosquitto.domain:8883
  ca: /app/data/ssl/ca.crt
  key: /app/data/ssl/zigbee2mqtt.key
  cert: /app/data/ssl/zigbee2mqtt.crt
  user: mqttService
  password: xxxxxxxx
  port: tcp://172.x.x.x:20108
  keepalive: 60
  reject_unauthorized: false
  version: 4
serial:
  adapter: zstack
frontend:
  enabled: true
  port: 8099
devices:
advanced:
  log_syslog:
    app_name: Zigbee2MQTT
    eol: /n
    host: localhost
    localhost: localhost
    path: /dev/log
    pid: process.pid
    port: 514
    protocol: udp4
    type: '5424'
  timestamp_format: DD.MM.YYYY HH:mm:ss
  channel: 25
  log_level: error
  last_seen: ISO_8601_local
device_options: {}
version: 4
Thanks @Spartacus
For reference to others, I also needed to set the following to make it work, otherwise all my automations were dead. The settings seem to be honoured if you put them in there.
advanced:
  homeassistant_legacy_triggers: true
