Hi since today my HA is not working anymore, well the MQTT part can’t start. I modified the configuration file like above, bit it still isn’t working. I restarted HA and rebooted, still not working. What am I missing?
I changed the adapter to zstack and added the lines after advanced.
Here is my file:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://core-mosquitto:1883
user: ****
password: ****
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00
adapter: zstack
advanced:
homeassistant_legacy_entity_attributes: false
homeassistant_legacy_triggers: false
legacy_api: false
legacy_availability_payload: false
device_options:
legacy: false
And maybe the log is helpful
[13:52:50] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-02-19 13:53:02] info: z2m: Logging to console, file (filename: log.log)
[2025-02-19 13:53:02] info: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-19 13:53:02] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-19 13:53:02] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-19 13:53:02] info: zh:zstack:znp: Serialport opened
[2025-02-19 13:53:03] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-19 13:53:04] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-19 13:53:04] error: z2m: Error while starting zigbee-herdsman
[2025-02-19 13:53:04] error: z2m: Failed to start zigbee-herdsman
[2025-02-19 13:53:04] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-19 13:53:04] error: z2m: Exiting...
[2025-02-19 13:53:04] error: z2m: Error: Error: Not supported, cannot set
[2025-02-19 13:53:04] info: zh:zstack:znp: Port closed
[13:53:07] INFO: Preparing to start...
[13:53:07] INFO: Socat not enabled
[13:53:08] INFO: Starting Zigbee2MQTT...
[2025-02-19 13:53:20] info: z2m: Logging to console, file (filename: log.log)
[2025-02-19 13:53:20] info: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-19 13:53:20] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-19 13:53:21] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-19 13:53:21] info: zh:zstack:znp: Serialport opened
[2025-02-19 13:53:21] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-19 13:53:23] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-19 13:53:23] error: z2m: Error while starting zigbee-herdsman
[2025-02-19 13:53:23] error: z2m: Failed to start zigbee-herdsman
[2025-02-19 13:53:23] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-19 13:53:23] error: z2m: Exiting...
[2025-02-19 13:53:23] error: z2m: Error: Error: Not supported, cannot set
[2025-02-19 13:53:23] info: zh:zstack:znp: Port closed
[13:53:26] INFO: Preparing to start...
[13:53:26] INFO: Socat not enabled
[13:53:27] INFO: Starting Zigbee2MQTT...
[2025-02-19 13:53:39] info: z2m: Logging to console, file (filename: log.log)
[2025-02-19 13:53:39] info: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-19 13:53:39] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-19 13:53:40] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-19 13:53:40] info: zh:zstack:znp: Serialport opened
[2025-02-19 13:53:40] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-19 13:53:41] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-19 13:53:41] error: z2m: Error while starting zigbee-herdsman
[2025-02-19 13:53:41] error: z2m: Failed to start zigbee-herdsman
[2025-02-19 13:53:41] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-19 13:53:41] error: z2m: Exiting...
[2025-02-19 13:53:41] error: z2m: Error: Error: Not supported, cannot set
[2025-02-19 13:53:41] info: zh:zstack:znp: Port closed
[13:53:44] INFO: Preparing to start...
[13:53:45] INFO: Socat not enabled
[13:53:46] INFO: Starting Zigbee2MQTT...
[2025-02-19 13:53:58] info: z2m: Logging to console, file (filename: log.log)
[2025-02-19 13:53:58] info: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-19 13:53:58] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-19 13:53:59] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-19 13:53:59] info: zh:zstack:znp: Serialport opened
[2025-02-19 13:53:59] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-19 13:54:00] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-19 13:54:00] error: z2m: Error while starting zigbee-herdsman
[2025-02-19 13:54:00] error: z2m: Failed to start zigbee-herdsman
[2025-02-19 13:54:00] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-19 13:54:00] error: z2m: Exiting...
[2025-02-19 13:54:00] error: z2m: Error: Error: Not supported, cannot set
[2025-02-19 13:54:00] info: zh:zstack:znp: Port closed
[13:54:04] INFO: Preparing to start...
[13:54:04] INFO: Socat not enabled
[13:54:05] INFO: Starting Zigbee2MQTT...
[2025-02-19 13:54:18] info: z2m: Logging to console, file (filename: log.log)
[2025-02-19 13:54:18] info: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-19 13:54:18] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-19 13:54:18] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-19 13:54:18] info: zh:zstack:znp: Serialport opened
[2025-02-19 13:54:19] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-19 13:54:20] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-19 13:54:20] error: z2m: Error while starting zigbee-herdsman
[2025-02-19 13:54:20] error: z2m: Failed to start zigbee-herdsman
[2025-02-19 13:54:20] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-19 13:54:20] error: z2m: Exiting...
[2025-02-19 13:54:20] error: z2m: Error: Error: Not supported, cannot set
[2025-02-19 13:54:20] info: zh:zstack:znp: Port closed
[13:54:24] INFO: Preparing to start...
[13:54:24] INFO: Socat not enabled
[13:54:25] INFO: Starting Zigbee2MQTT...
[2025-02-19 13:54:37] info: z2m: Logging to console, file (filename: log.log)
[2025-02-19 13:54:37] info: z2m: Starting Zigbee2MQTT version 2.1.1 (commit #unknown)
[2025-02-19 13:54:37] info: z2m: Starting zigbee-herdsman (3.2.5)
[2025-02-19 13:54:38] info: zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124210837-if00","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-02-19 13:54:38] info: zh:zstack:znp: Serialport opened
[2025-02-19 13:54:38] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-02-19 13:54:39] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-02-19 13:54:39] error: z2m: Error while starting zigbee-herdsman
[2025-02-19 13:54:39] error: z2m: Failed to start zigbee-herdsman
[2025-02-19 13:54:39] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-02-19 13:54:39] error: z2m: Exiting...
[2025-02-19 13:54:39] error: z2m: Error: Error: Not supported, cannot set
[2025-02-19 13:54:39] info: zh:zstack:znp: Port closed
