Zigbee2MQTT not starting with "Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
So, to confirm, I can’t have ZHA and Z2M running concurrently, even with two separate dongles?
You can have ZHA and Z2M running concurrently, only with two separate dongles.
Thanks!!!
Man, You nailed it!
And here’s another one rescued by this nugget of information! Thanks for much for posting it. I’ve tried so many things including getting it all working just fine with ZHA.
I deeply love you!
… and Boom! It works, thank you!
Try to check if the USB device is still where you think it is. In my case (HAOS in a VM) the VM manager once changed the USB port and everything stopped working.
You can use install and connect to the terminal and type the command ha hardware info to see the devices recognized by HA, and you’ll see an -attribute section with the usb device paths under which you can find your adapter (if the system can see it…)
- attributes:
    DEVLINKS: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230329090913-if00
      /dev/serial/by-path/pci-0000:00:03.0-usb-0:1:1.0
    DEVNAME: /dev/ttyACM0
That was for me! THANKS!
Woaw !! Big hug to you !! it was that !!!
Thank you! That worked for me too!
You are a great and nice person. I solved the problem too!
you are an effing god <3
Thank you my friend, that fixed also my problem.
i replicated your config, typing over my device id.
Finaly worked! thanks!
Thank you, thank you, thank you,… very, very much
Thank You
i was fighting with this 2 days
Still struggling to get this working.
Here is my config…
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt: {}
serial:
  port: >-
    /dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_aa2561b9fde1ed119eeaeb5162c613ac-if00-port0
  adapter: ezsp
zigbee_herdsman_debug: true
Got my Sky Connect’s ID from the All Hardware part of the settings menu…
But when I start Zigbee2MQTT it all goes Pete Tong.
Here is my log.
[21:12:39] INFO: Preparing to start...
[21:12:41] INFO: Socat not enabled
[21:12:41] INFO: Zigbee Herdsman debug logging enabled
[21:12:47] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2024-02-26 21:12:57: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info  2024-02-26 21:12:57: Logging to console and directory: '/config/zigbee2mqtt/log/2024-02-26.21-12-57' filename: log.txt
Zigbee2MQTT:debug 2024-02-26 21:12:57: Removing old log directory '/config/zigbee2mqtt/log/2024-02-26.20-51-09'
Zigbee2MQTT:info  2024-02-26 21:12:57: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info  2024-02-26 21:12:57: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:debug 2024-02-26 21:12:57: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[13,76,231,110,155,208,162,218],"networkKey":"HIDDEN","panID":49632},"serialPort":{"adapter":"ezsp","path":"/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_aa2561b9fde1ed119eeaeb5162c613ac-if00-port0"}}'
2024-02-26T21:12:57.980Z zigbee-herdsman:adapter Failed to validate path: 'Error: spawn udevadm ENOENT'
2024-02-26T21:12:57.984Z zigbee-herdsman:adapter:ezsp:debg Adapter concurrent: 8
2024-02-26T21:12:57.987Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[149,120,112,233,130,107,24,244,9,114,180,116,104,231,50,3],"panID":49632,"extendedPanID":[13,76,231,110,155,208,162,218],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_aa2561b9fde1ed119eeaeb5162c613ac-if00-port0","adapter":"ezsp"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2024-02-26T21:12:57.993Z zigbee-herdsman:adapter:ezsp:uart RTS/CTS config is off, enabling software flow control.
2024-02-26T21:12:57.994Z zigbee-herdsman:adapter:ezsp:uart Opening SerialPort with {"path":"/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_aa2561b9fde1ed119eeaeb5162c613ac-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
2024-02-26T21:12:58.051Z zigbee-herdsman:adapter:ezsp:uart Serialport opened
2024-02-26T21:12:58.053Z zigbee-herdsman:adapter:ezsp:uart Uart reseting
2024-02-26T21:12:58.055Z zigbee-herdsman:adapter:ezsp:uart --> Write reset
2024-02-26T21:12:58.059Z zigbee-herdsman:adapter:ezsp:uart --> [1ac038bc7e]
2024-02-26T21:12:58.062Z zigbee-herdsman:adapter:ezsp:uart -?- waiting reset
2024-02-26T21:12:59.146Z zigbee-herdsman:adapter:ezsp:uart <-- [c1020b0a527ea0547d3a7e]
2024-02-26T21:12:59.148Z zigbee-herdsman:adapter:ezsp:uart --> parsed c1020b0a527e
2024-02-26T21:12:59.150Z zigbee-herdsman:adapter:ezsp:uart <-- RSTACK c1020b0a527e
2024-02-26T21:12:59.152Z zigbee-herdsman:adapter:ezsp:uart RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
2024-02-26T21:12:59.156Z zigbee-herdsman:adapter:ezsp:uart --> parsed a0541a7e
2024-02-26T21:12:59.157Z zigbee-herdsman:adapter:ezsp:uart <-- NAK (0): a0541a7e
2024-02-26T21:12:59.158Z zigbee-herdsman:adapter:ezsp:uart NAK Unexpected packet sequence 0
2024-02-26T21:12:59.159Z zigbee-herdsman:adapter:ezsp:uart -+- waiting reset success
2024-02-26T21:12:59.161Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {"desiredProtocolVersion":4}
2024-02-26T21:12:59.163Z zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":4}
2024-02-26T21:12:59.166Z zigbee-herdsman:adapter:ezsp:uart --> DATA (0,0,0): 00000004
2024-02-26T21:12:59.168Z zigbee-herdsman:adapter:ezsp:uart --> [004221a850ed2c7e]
2024-02-26T21:12:59.169Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (1)
2024-02-26T21:12:59.175Z zigbee-herdsman:adapter:ezsp:uart <-- [0142a1a85d2805c332237e]
2024-02-26T21:12:59.176Z zigbee-herdsman:adapter:ezsp:uart --> parsed 0142a1a85d2805c332237e
2024-02-26T21:12:59.177Z zigbee-herdsman:adapter:ezsp:uart <-- DATA (0,1,0): 0142a1a85d2805c332237e
2024-02-26T21:12:59.177Z zigbee-herdsman:adapter:ezsp:uart --> ACK  (1)
2024-02-26T21:12:59.178Z zigbee-herdsman:adapter:ezsp:uart --> [8160597e]
2024-02-26T21:12:59.180Z zigbee-herdsman:adapter:ezsp:uart <-- ACK (1): 0142a1a85d2805c332237e
2024-02-26T21:12:59.181Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 00800009021071
2024-02-26T21:12:59.185Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x0: {"_cls_":"version","_id_":0,"_isRequest_":false,"protocolVersion":9,"stackType":2,"stackVersion":28944}
2024-02-26T21:12:59.186Z zigbee-herdsman:adapter:ezsp:uart -+- waiting (1) success
2024-02-26T21:12:59.187Z zigbee-herdsman:adapter:ezsp:ezsp Switching to eszp version 9
2024-02-26T21:12:59.188Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {"desiredProtocolVersion":9}
2024-02-26T21:12:59.188Z zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":9}
2024-02-26T21:12:59.191Z zigbee-herdsman:adapter:ezsp:uart --> DATA (1,1,0): 010001000009
2024-02-26T21:12:59.191Z zigbee-herdsman:adapter:ezsp:uart --> [7d314321a9542a1cd95e7e]
2024-02-26T21:12:59.192Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (2)
2024-02-26T21:13:01.195Z zigbee-herdsman:adapter:ezsp:uart --> Error: Error: {"sequence":2} after 2000ms
2024-02-26T21:13:01.195Z zigbee-herdsman:adapter:ezsp:uart -!- break waiting (2)
2024-02-26T21:13:01.196Z zigbee-herdsman:adapter:ezsp:uart Can't send DATA frame (1,1,0): 010001000009
2024-02-26T21:13:01.698Z zigbee-herdsman:adapter:ezsp:uart ->> DATA (1,1,1): 010001000009
2024-02-26T21:13:01.699Z zigbee-herdsman:adapter:ezsp:uart --> [194321a9542a1c4af37e]
2024-02-26T21:13:01.701Z zigbee-herdsman:adapter:ezsp:uart -?- rewaiting (2)
2024-02-26T21:13:03.702Z zigbee-herdsman:adapter:ezsp:uart --> Error: Error: {"sequence":2} after 2000ms
2024-02-26T21:13:03.703Z zigbee-herdsman:adapter:ezsp:uart -!- break rewaiting (2)
2024-02-26T21:13:03.703Z zigbee-herdsman:adapter:ezsp:uart Can't resend DATA frame (1,1,1): 010001000009
2024-02-26T21:13:03.703Z zigbee-herdsman:adapter:ezsp:ezsp onSerialReset()
2024-02-26T21:13:03.704Z zigbee-herdsman:adapter:ezsp:driv onEzspReset()
2024-02-26T21:13:03.705Z zigbee-herdsman:adapter:ezsp:driv Reset connection.
2024-02-26T21:13:03.705Z zigbee-herdsman:adapter:ezsp:driv Stopping driver
2024-02-26T21:13:03.706Z zigbee-herdsman:adapter:ezsp:ezsp Closing Ezsp
2024-02-26T21:13:03.707Z zigbee-herdsman:adapter:ezsp:uart Closing UART
Zigbee2MQTT:error 2024-02-26 21:13:03: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-02-26 21:13:03: Failed to start zigbee
Zigbee2MQTT:error 2024-02-26 21:13:03: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-02-26 21:13:03: Exiting...
Zigbee2MQTT:error 2024-02-26 21:13:03: Error: Failure send version:{"type":"Buffer","data":[1,0,1,0,0,9]}
    at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:646:23
    at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
    at Ezsp.version (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:456:13)
    at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:167:9)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:60:27)
    at Controller.start (/app/lib/controller.ts:109:27)
    at start (/app/index.js:107:5)
2024-02-26T21:13:03.960Z zigbee-herdsman:adapter:ezsp:uart Port closed. Error? null
2024-02-26T21:13:03.960Z zigbee-herdsman:adapter:ezsp:ezsp onSerialClose()
2024-02-26T21:13:03.961Z zigbee-herdsman:adapter:ezsp:driv onEzspClose()
2024-02-26T21:13:03.962Z zigbee-herdsman:adapter:ezsp:debg onDriverClose()
Any suggestions?
Thanks in advance fro your help!
Cheers,
Dan
Try this in your serial settings instead:
port: /dev/ttyUSB0
ZHA is disabled / not installed ?
