Currently in Thailand and long way from home and this happens. Murphys law!
Rebooted, restored and restarted my NUC running PVE.
Any suggestions? Help is really needed!
02:09:05] INFO: Preparing to start...
[02:09:05] INFO: Socat not enabled
[02:09:06] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:error 2024-03-25 02:09:27: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-25 02:09:27: Failed to start zigbee
Zigbee2MQTT:error 2024-03-25 02:09:27: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-25 02:09:27: Exiting...
Zigbee2MQTT:error 2024-03-25 02:09:27: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
I have the same issue, i tried everything above and still not working.
Do you have any suggestions?
1st i tried my dongle with ZHA and itâs ok.
Then i disable ZHA and follow a tutorial to install Z2M.
mosquito seems ok
my config : raspberry 4 running HA OS with SONOFF Zigbee 3.0 USB Dongle Plus - TI CC2652P
Problem solved for me !
The config was ok in the add-on but when i checked the file /homeassistant/zigbee2mqtt/configuration.yaml I noticed that I had an old configuration for another zigbee module.
Once the module configuration has been reported directly in the Z2M file, it has started.
