I’ve had zigbee2mqtt working for a while now. I use zigbee2mqttassistant for the web interface, and up until the past month or two, it’s worked fine.
Here’s the issues I’m having:
- zigbee2mqttassistant map has no connecting lines. I’ve reset local state several times, and nothing.
- “allow new devices to join network” doesn’t work once clicked.
The default zigbee2mqtt web UI has nothing actually load. I can see the various tabs/pages, but nothing is actually loaded. I just get “loading please wait”.
Any ideas? I can’t add any devices now, since the “add new devices” just spins/loads. on the default zigbee2mqtt web ui, the Permit Join button does the same.
My zigbee network has a CC2531 main controller, and then (2) CC2530 routers to repeat the signal throughout the house.
