Hi folks,
I read the Release notes 1.25.0 for Zigbee2MQTT last night and was confused a bit.
It says:
- All your Zigbee devices will stop working (we hope this is not a problem for you)
Important for users running Raspbian Buster: due to #11804,
libseccomp2
is required which needs to be installed manually. If you do not do this the container will crash on startup. See the docs on how to do this.
Did anyone running Rasbian buster upgrade to this version? What does this mean? Should I change to a different Zigbee to MQTT solution?
Regards,
AK
