Zigbee2mqtt problem with network
Hi there!
I’m having big issues with zigbee2mqtt losing connection to devices all the time, it seems to be the same devices.
I can’t operate the device from home assistant or z2m from dashboard. But if I go inside z2m expose and click “on/off” the device pops up again.
The LQI for most of the devices is around 100-150 first poll and then goes when being used frequently.
All the devices that fails are IKEA device that was functioning with IKEA hub just before moving over to z2m with Deconz conbee2.
Best Regards,
Viktor
Do you have your ConBee II on a USB-extension cable (1-2 Meter / 3-6 feet) so there is not interference from the USB 3 ports?
Yes, I use a short usb cable < 1m
