Zigbee2mqtt, raspbee 2 and HAOS failure to connect
Ive been trying to get zigbee2mqtt to work with raspbee 2 wiht failure.
my setup is following:
HAOS running on nuc intel
raspbee 2 running on raspberry pi 4
It seems that im not able to find raspbee 2 from HA machine however I can find it on my raspberry pi.
Before I desided to move from deconz to zigbee2mqtt it all worked well with deconz.
zigbee2mqtt log:
[2024-05-21 21:05:28] info: z2m: Logging to console, file (filename: log.log)
[2024-05-21 21:05:28] info: z2m: Starting Zigbee2MQTT version 1.37.1 (commit #unknown)
[2024-05-21 21:05:28] info: z2m: Starting zigbee-herdsman (0.46.6)
[2024-05-21 21:05:28] error: zh:zstack:znp: Failed to determine if path is valid: ‘Error: ENOENT: no such file or directory, lstat ‘/dev/serial’’
[2024-05-21 21:05:28] info: zh:zstack:znp: Opening SerialPort with {path:/dev/serial/by-id/usb-0658_0200-if00,baudRate:115200,rtscts:false,autoOpen:false}
[2024-05-21 21:05:28] error: z2m: Error while starting zigbee-herdsman
[2024-05-21 21:05:28] error: z2m: Failed to start zigbee
[2024-05-21 21:05:28] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-05-21 21:05:28] error: z2m: Exiting…
[2024-05-21 21:05:28] error: z2m: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-0658_0200-if00
zigbee2mqtt config file:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt:
server: mqtt://core-mosquitto:1883
user:
password:
serial:
port: /dev/ttyAMA0
adapter: deconz
