Hey there,
I just transitioned from SD card to SSD on my RasPi4 with RaspBee II as ZigBee adapter.
After restoring my Backup everything works fine except Zigbee2MQTT…
Of course I did the research and here is what I´ve tried already:
- Use long USB cable for SSD
- Use powered USB-Hub
- Try all USB-Ports
- and I even used 2 sets of jumper cables to move the RaspBee II further away from the RasPi, so now my setup is positioned like this on my desk:
RasbBee II --------0,5m/19in Jumper cable ------- RasPi4 -------- 1m/40in USB cable --------- SSD
These are all the possible Solutions I could find so I would really appreciate your help guys!
Edit: I remember having the same error once before after a power outage but all I did to resolve this was doing several reboots and this didnt help so far…
Edit2: I put the RasPi in between 2 aluminum dishes with the RaspBeeII hanging out but the error stays the same…
Edit3: Disconnected SSD, booted from SD = everything works; connected the SSD and rebooted z2MQTT = still works…
Edit4: Updated the Firmware on the RaspBee II but still the same error
Log (repeating):
CREATED DECONZ ADAPTER
Zigbee2MQTT:error 2022-03-26 18:42:38: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-03-26 18:42:38: Failed to start zigbee
Zigbee2MQTT:error 2022-03-26 18:42:38: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-03-26 18:42:38: Exiting...
Zigbee2MQTT:error 2022-03-26 18:42:38: undefined
[18:42:38] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Config:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: /dev/ttyAMA0
adapter: deconz
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
UserInterface → Supervisor → Hardware → TTYAMA0:
DEVLINKS: /dev/serial1
DEVNAME: /dev/ttyAMA0
DEVPATH: /devices/platform/soc/fe201000.serial/tty/ttyAMA0
MAJOR: '204'
MINOR: '64'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '3369964'
