anyone using this module from dresden and have a Zigbee2MQTT config they can share? i cant get it to start… it starts but i get the bad gateway and it crashes sooner or later
config last tried:
data_path: /config/zigbee2mqtt
socat:
enabled: true
master: pty,raw,echo=0,link=/dev/ttyAMA0,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://localhost:1883
user: homeassistant
password: xxxxxxxx
serial:
port: /dev/ttyAMA0
homeassistant: true
permit_join: true
frontend: true
zigbee_herdsman_debug: true
advanced:
network_key: GENERATE
