Hi there, I think I have a problem with my zigbee2mqtt setup because in my logs there are way to many messages for that timeframe could anyone tell me if this is expected behavior
2023-12-23 11:50:32Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":15330}' from endpoint 1 with groupID 0
2023-12-23 11:50:32Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":15586}' from endpoint 1 with groupID 0
2023-12-23 11:50:32Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":15842}' from endpoint 1 with groupID 0
2023-12-23 11:50:32Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":8418}' from endpoint 1 with groupID 0
2023-12-23 11:50:32Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":8674}' from endpoint 1 with groupID 0
2023-12-23 11:50:32Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":8930}' from endpoint 1 with groupID 0
2023-12-23 11:50:33Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":9186}' from endpoint 1 with groupID 0
2023-12-23 11:50:33Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,24],"type":"Buffer"},"datatype":2,"dp":16}],"seq":14562}' from endpoint 1 with groupID 0
2023-12-23 11:50:35Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":8450}' from endpoint 1 with groupID 0
2023-12-23 11:50:36Received Zigbee message from 'Steckdose5_16A', type 'attributeReport', cluster 'genBasic', data '{"65506":54,"65508":0,"appVersion":192}' from endpoint 1 with groupID 0
2023-12-23 11:50:37Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":14562}' from endpoint 1 with groupID 0
2023-12-23 11:50:37Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1950}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":14818}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":15074}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":15330}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":15586}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":15842}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":16098}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":16354}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":18914}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":19170}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":19426}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":19682}' from endpoint 1 with groupID 0
2023-12-23 11:50:38Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":19938}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":24802}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":25058}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":25314}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":25570}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":25826}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":28130}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":28386}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":28642}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":28898}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":29154}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":29410}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":29666}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":34786}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":35042}' from endpoint 1 with groupID 0
2023-12-23 11:50:39Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":2107}' from endpoint 1 with groupID 0
2023-12-23 11:50:40Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":2107}' from endpoint 1 with groupID 0
2023-12-23 11:50:40Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":29666}' from endpoint 1 with groupID 0
2023-12-23 11:50:40Received Zigbee message from 'ThermostatBad-FB', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[1],"type":"Buffer"},"datatype":4,"dp":36}],"seq":46306}' from endpoint 1 with groupID 0
2023-12-23 11:50:41Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":10021}' from endpoint 1 with groupID 0
2023-12-23 11:50:45Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":9671}' from endpoint 1 with groupID 0
2023-12-23 11:50:47Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'seMetering', data '{"currentSummDelivered":[0,810]}' from endpoint 1 with groupID 0
2023-12-23 11:50:47Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":2003}' from endpoint 1 with groupID 0
2023-12-23 11:50:50Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":8442}' from endpoint 1 with groupID 0
2023-12-23 11:50:52Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1934}' from endpoint 1 with groupID 0
2023-12-23 11:50:58Received Zigbee message from 'Steckdose2_20A', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":10135}' from endpoint 1 with groupID 0
2023-12-23 11:50:58
Thanks for all your help
