forked from @mbacks Z2M - Tint Remote blueprint.
31 Jan '25 - UPDATE for Zigbee2MQTT 2.0 coming soon.
In order to meet the requirements of Home Assistant moving to Device Action triggers, Zigbee2MQTT 2.0 update broke the functionality of the RGB Genie ZB-5004, and modified the behaviour of the RGB Genie ZB-5028, which means that my blueprint no longer works.
I’ve created an external converter for the ZB-5004 (below) which converts the remote to be compliant with HA Device Triggers, however, I’ve extended the Scene controls, so that it mimics the behaviour of the ZB-5028, in that it now has actions for recall 1 and 2 for zones 1-4. To select the zone, press an on or off for the particular zone and then press the required S1 or S2 button. If you don’t want to do that, just set the same scene 1 or scene 2 action for all 4 zones (once I deliver the new blueprint).
V 1.1 - 13 Jul '21 - added input_boolean to monitor brightness_ & hue_stop commands. This allows the automation to run in parallel mode so that ZB-5004 Master On/Off’s work correctly while still monitoring for the stop button while in loops.
Written for RGBGenie ZB-5008/5028 RGBW Multi-Zone Remote Control (4 Zones / 3 Scenes per zone / On/Off/Dimmer/Color wheel and Color Temp/Hue controls) and RGBGenie ZB-5004 (4 Zones / 2 Scenes / On/Off/ Dimmer remote) or RGBGenie ZB-5001 (5 Zones / On/Off/ Dimmer remote) but you can populate as few or as many as you want. I’ve allowed up to (optional - will not break with less) 5 zones and can call up to (optional - will not break from 0 - 12) 12 scenes which can adjust any entity/ies via HA (i.e. not just lights). Only the first 2 Scenes will be recalled with ZB-5004 and none for ZB-5001.
You will need to create an input_boolean helper from Configuration>Helpers>Toggle screen.
Should work out of the box with Iluminize 511.314, RGBGenie controllers and any Sunricher whitelabel remotes with same or similar functions.
By changing the relevant button names (color_move == color wheel, etc) should work (with some editing) with: Müller Licht Tint 404011, Namron 4512706, Sunricher SR-ZG2868 (you will need to adjust for the scene recalls) Sunricher ZGRC-KEY-013, RGBGenie 3 Zone RGBW Wall Panel, RGBGenie ZB-5001/4/x 3/4/5 Zone on/off/dimmer/scenes remote or Namron equivalents (4512706).
If your remote control uses the action_group attribute (ZB-5004/1 e.g.) and does not give you a “zone/group_id” appended to the button press, look at @mbacks “Z2M - Tint Remote blueprint” to re-implement the action_group logic (maybe include some input selectors fro the group’s if you publish back here). Set the remote type to ZB-5004/1 (switch on) within the input selectors. As an aside, all of these remotes seem to use different 5 digit action_group id’s per zone, even from same manufacturer.
The ZB-5008/5028 button’s include:
on/off/color_move/hue_move/color_temperature_move/brightness_step_up/down brightness_move_up/down/stop,recall_1/2/3 followed by a zone:_1/2/3/4 for all of the commands except zone 1 on/off (see 1. and 2. below)!
The ZB-5004 button’s include:
on/off/brightness_move_up/down/stop,recall_1/2 . The scene recall is sent for all zones, but I have coded as a scene automation, so it just recalls scene 1 or 2.
The ZB-5001 button’s include:
The RGBGenie ZB-5008/5028 has a few quirks…
The big Power button controls Zone 1. If it is off, the remote is asleep, and wont wake up until you press it, so individual zone buttons 1/2/3/4 do nothing unless Zone 1 is on.
The remote provides an “action_group” number for any button press addressed to zones 2/3/4, but none for zone 1, hence the way I have chosen to code the zone (group_id). If you wanted to turn off all light_groups with the big on-off button, turn zone 1 into a control group by adding all your lights to light_group_1.
This automation does not care what button is pressed as long as it contains an “_”. If you are unsure what command is sent when buttons are being pressed, monitor your HA log and look at the info. Comment out the log service once you are happy.
The ZB-5001/ZB-5004 Main On/Off sends On/Off for each individual Zone (1-5)
ToDo:
1. write some logic for hue_move action. (done in 2021…)I don’t really see my need of this button, because you can just touch the color wheel, and instant color change. I’ve worked out that the Zigbee2MQTT converter for this remote is not passing the attributes through correctly, and will push a change to correct so that when the button is pressed and held, it will send hue_move and a “rate”, and send hue_stop when released.
2. fix the brightness_move logic to recognise brightness_stop button to end the loop.
3. Redo Template to handle HA Device Actions. The old one will work with HA Legacy Triggers enabled in Zigbee2MQTT (See Breaking Changes in Z2M Release Notes).
blueprint:
name: Z2M - RGBGenie ZB-5008/5028 or ZB-5004 4 Zone Remote 1.1
description: Control lights with a RGBGenie ZB 5008/5028 RGBW or ZB-5004 Dimmer 4 Zone Remote v1.0
domain: automation
input:
remote:
description: Choose the Remote Control Sensor.action to use
selector:
entity:
integration: mqtt
domain: sensor
zb_5004:
name: Remote Type = ZB-5004 / ZB-5001 or similar?
description: Turn On if this is a ZB-5004 (you want to use the "action_group" attribute to choose zones rather than receiving zone info from the "action" attribute). Default is ZB-5008/5028
default: false
selector:
boolean: {}
helper_stop_button:
name: Helper - Brightness or Hue Stop
description: Input Boolean used to monitor receipt of a brightness_stop or hue_stop button. Needs to be created before creating automation Configuration>Helpers>Toggle
default: {}
selector:
entity:
domain: input_boolean
remote_zone_1_action_group:
name: (Change if ZB-5004 / ZB-5001 - otherwise it is ignored) ZB-5004 Zone 1 Action Group ID
description: Enter the 5 digit "action_group" for Zone 1 - look at Z2M log when you press Master On/Off or 1st Zone Button On/Off
default: 48897
selector:
number:
min: 1
max: 99999
mode: box
step: 1
remote_zone_2_action_group:
name: (Change if ZB-5004 / ZB-5001 - otherwise it is ignored) ZB-5004 Zone 2 Action Group ID
description: Enter the 5 digit "action_group" for Zone 2 - look at Z2M log when you press Master On/Off or 1st Zone Button On/Off
default: 48898
selector:
number:
min: 1
max: 99999
mode: box
step: 1
remote_zone_3_action_group:
name: (Change if ZB-5004 / ZB-5001 - otherwise it is ignored) ZB-5004 Zone 3 Action Group ID
description: Enter the 5 digit "action_group" for Zone 3 - look at Z2M log when you press Master On/Off or 1st Zone Button On/Off
default: 48899
selector:
number:
min: 1
max: 99999
mode: box
step: 1
remote_zone_4_action_group:
name: (Change if ZB-5004 / ZB-5001 - otherwise it is ignored) ZB-5004 Zone 4 Action Group ID
description: Enter the 5 digit "action_group" for Zone 4 - look at Z2M log when you press Master On/Off or 1st Zone Button On/Off
default: 48900
selector:
number:
min: 1
max: 99999
mode: box
step: 1
remote_zone_5_action_group:
name: (Change if ZB-5001 - otherwise it is ignored) ZB-5001 or other 5 zone remote - Zone 5 Action Group ID
description: Enter the 5 digit "action_group" for Zone 5 - look at Z2M log when you press Master On/Off or 1st Zone Button On/Off
default: 48901
selector:
number:
min: 1
max: 99999
mode: box
step: 1
light_group_1:
name: Optional - light group 1
default: {}
selector:
entity:
domain: light
light_group_2:
name: Optional - light group 2
default: {}
selector:
entity:
domain: light
light_group_3:
name: Optional - light group 3
default: {}
selector:
entity:
domain: light
light_group_4:
name: Optional - light group 4
default: {}
selector:
entity:
domain: light
light_group_5:
name: Optional - light group 5 (if 5 zone remote e.g.)
default: {}
selector:
entity:
domain: light
scene_1_1:
name: scene 1 zone 1
description: Optional - Enter Scene 1 for ZB-5004 or Scene 1 Zone 1 for ZB-5028
default: {}
selector:
entity:
domain: scene
scene_2_1:
name: scene 2 zone 1
description: Optional - Enter Scene 2 for ZB-5004 or Scene 2 Zone 1 for ZB-5028
default: {}
selector:
entity:
domain: scene
scene_3_1:
name: scene 3 zone 1
description: Optional - ZB-5028 only
default: {}
selector:
entity:
domain: scene
scene_1_2:
name: scene 1 zone 2
default: {}
selector:
entity:
domain: scene
scene_2_2:
name: scene 2 zone 2
default: {}
selector:
entity:
domain: scene
scene_3_2:
name: scene 3 zone 2
default: {}
selector:
entity:
domain: scene
scene_1_3:
name: scene 1 zone 3
default: {}
selector:
entity:
domain: scene
scene_2_3:
name: scene 2 zone 3
default: {}
selector:
entity:
domain: scene
scene_3_3:
name: scene 3 zone 3
default: {}
selector:
entity:
domain: scene
scene_1_4:
name: scene 1 zone 4
default: {}
selector:
entity:
domain: scene
scene_2_4:
name: scene 2 zone 4
default: {}
selector:
entity:
domain: scene
scene_3_4:
name: scene 3 zone 4
default: {}
selector:
entity:
domain: scene
variables:
remote_type_zb_5004: !input zb_5004
stop_button_received: !input 'helper_stop_button'
stopper: !input 'helper_stop_button'
remote_action_group:
- !input remote_zone_1_action_group
- !input remote_zone_2_action_group
- !input remote_zone_3_action_group
- !input remote_zone_4_action_group
- !input remote_zone_5_action_group
light_entities:
- !input light_group_1
- !input light_group_2
- !input light_group_3
- !input light_group_4
- !input light_group_5
scene_entities:
- !input scene_1_1
- !input scene_2_1
- !input scene_3_1
- !input scene_1_2
- !input scene_2_2
- !input scene_3_2
- !input scene_1_3
- !input scene_2_3
- !input scene_3_3
- !input scene_1_4
- !input scene_2_4
- !input scene_3_4
mode: parallel
max: 5
max_exceeded: silent
- platform: state
entity_id: !input 'remote'
condition:
- condition: and
conditions:
- condition: template
value_template: '{{ trigger.from_state.state != trigger.to_state.state }}'
value_template: "{% if remote_type_zb_5004 %} {{ trigger.to_state.attributes.action in ('off', 'on', 'brightness_move_down', 'brightness_move_up', 'brightness_stop', 'recall_1', 'recall_2' ) }} {% else %} {{ trigger.to_state.attributes.action.find('_') != -1 }} {% endif %}"
- variables:
button_group_press: '{% if not remote_type_zb_5004 %} {{ trigger.to_state.attributes.action.rsplit("_", 1) }} {% endif %}'
button: '{% if remote_type_zb_5004 %} {{ trigger.to_state.attributes.action | string }} {% else %} {{ button_group_press[0] | string }} {% endif %}'
group_id: '{% if remote_type_zb_5004 %}{{ remote_action_group.index(trigger.to_state.attributes.action_group) | int }} {% else %} {{ button_group_press[1] | int }} {% endif %}'
light_target: '{% if remote_type_zb_5004 %}{{ light_entities[group_id] }} {% else %} {{ light_entities[group_id - 1] }} {% endif %}'
recall_found: '{{ ( "recall" ) in button }}'
recall_press: '{% if recall_found %} {{ button.rsplit("_", 1) }} {% endif %}'
recall_scene: '{% if recall_found %} {{ recall_press[1] | int }} {% endif %}'
recall_scene_index: '{% if recall_found %} {{ (recall_scene - 1 | int) if remote_type_zb_5004 else (((group_id - 1) * 3) + recall_scene - 1 | int) }} {% endif %}'
scene_target: '{% if recall_found %} {{ scene_entities[recall_scene_index] }} {% endif %}'
scene_target_valid: '{% if (scene_target | length) > 0 %} {{ true }} {% else %} {{ false }} {% endif %}'
- service: system_log.write
level: info
message: 'ZB-5028/5004 Button pressed: {{ trigger.to_state.state }} {{ trigger.to_state.attributes }} Length {{ trigger.to_state.attributes.action | length }} Button {{ button }} Zone {{ group_id }}'
- choose:
- conditions:
value_template: '{{ button in ( "on", "off" ) }}'
sequence:
- service: light.turn_{{ button }}
data: {}
target: '{{ light_target }}'
- conditions:
value_template: '{{ button in ( "color_move" ) }}'
sequence:
- service: light.turn_on
data_template:
xy_color:
- '{{ trigger.to_state.attributes.action_color.x | float }}'
- '{{ trigger.to_state.attributes.action_color.y | float }}'
- conditions:
value_template: '{{ button in ( "brightness_stop " ) }}'
sequence:
level: info
message: 'stop button received: {{ trigger.to_state.state }} {{ trigger.to_state.attributes }} Button {{ button }} Zone {{ group_id }}'
entity_id: !input 'helper_stop_button'
- conditions:
value_template: '{{ button in ( "brightness_move_up", "brightness_move_down" ) }}'
sequence:
- service: input_boolean.turn_off
- repeat:
while: '{{ repeat.index < 50 and states(stopper) == "off" }}'
sequence:
- delay: 0.3
- choose:
- conditions: '{{ button in ( "brightness_move_up" , "brightness_move_down" ) }}'
sequence:
- variables:
factor: '{% if button in ( "brightness_move_down" ) %} -{{ trigger.to_state.attributes.action_rate / 2| int }} {% else %} {{ trigger.to_state.attributes.action_rate / 2 | int }} {% endif %}'
level: info
message: 'In the LOOP: Iteration {{ repeat.index }} Button {{ button }} Group {{ group_id }}'
data_template:
brightness_step: '{{ factor | int }}'
- conditions:
value_template: '{{ recall_found and scene_target_valid }}'
sequence:
- service: scene.turn_on
transition: 2
target: '{{ scene_target }}'
- conditions:
value_template: '{{ button in ( "color_temperature_move" ) }}'
sequence:
data_template:
color_temp: '{{ trigger.to_state.attributes.action_color_temperature | int }}'
- conditions:
value_template: '{{ button in ( "brightness_step_up", "brightness_step_down" ) }}'
sequence:
- variables:
factor: '{% if button in ( "brightness_step_down" ) %} -{{ trigger.to_state.attributes.action_step_size /2 | int }} {% else %} {{ trigger.to_state.attributes.action_step_size /2 | int }} {% endif %}'
data_template:
- conditions:
value_template: '{{ button in ( "hue_move" ) }}'
sequence: []
default: []
Zigbee2MQTT 2.0 External Converter for ZB-5004 to work with HA Device Action Triggers - January 2025.
const {deviceEndpoints, battery, commandsOnOff, commandsLevelCtrl, commandsColorCtrl, commandsScenes} = require('zigbee-herdsman-converters/lib/modernExtend');
const definition = {
zigbeeModel: ['RGBgenie ZB-5004'],
model: 'RGBgenie ZB-5004',
vendor: 'RGBgenie',
description: 'Zigbee 3.0 dimmer remote with 4 zones and 2 scene recalls',
extend: [deviceEndpoints({"endpoints":{"1":1,"2":2,"3":3,"4":4}}), battery(), commandsOnOff({"endpointNames":["1","2","3","4"]}), commandsLevelCtrl({"endpointNames":["1","2","3","4"]}), commandsColorCtrl({"endpointNames":["1","2","3","4"]}), commandsScenes({"endpointNames":["1","2","3","4"]})],
meta: {"multiEndpoint":true},
module.exports = definition;
