I just installed zigbee2mqtt yesterday running with the Sonoff wireless ZigBee bridge. Everything seems to be working fine but when I check the log I get quite a few of the “assertion failed” errors. Where else can I go to find information about this error. Forum and Google didn’t really turn up anything useful.
Zigbee2mqtt
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[19:04:12] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[19:04:13] INFO: MQTT available, fetching server detail ...
[19:04:14] INFO: Previous config file found, checking backup
[19:04:14] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[19:04:14] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:04:15] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Assertion failed
Assertion failed
Zigbee2MQTT:warn 2021-11-30 19:04:33: Using experimental new availability feature
Zigbee2MQTT:warn 2021-11-30 19:10:48: Device '0x00158d00035390ff' left the network
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
Assertion failed
