Zigbee2Mqtt - Seeing states reported in Log but not in HA
Hello
I got a problem configuring my zigbee sensors in HA.
I have installed and configured mosquitto broker and zigbee2mqtt. I also already was able to pair some devices and i can see the states changing in the zigbee2mqtt log like this:
zigbee2mqtt:info 2020-04-11 12:25:43: MQTT publish: topic 'zigbee2mqtt/0x00158d0002e9d384', payload '{"contact":true,"linkquality":52,"battery":100,"voltage":3005}'
The problem now is that Homeassistant dont get any updates on the states of the devices. State is unknown when i check it under Settings -> Integrations -> MQTT:
I now removed all configured zigbee sensors from the configuration.yaml file but this somehow changes nothing. I can still see all the sensors like in the picture above. Where do these devices get configured? Or am I mixing stuff up with the MQTT Integration of HA while i am also running mosquitto broker?
Hope somebody can clear this up as i am quite stuck here.
Thanks in advance!
Happ easter :rabbit2:
I have the same issue, clicking the button updates in zigbee2mqtt logs but nothing is visible in HA
