Zigbee2mqtt: set payload with helper input_number
To set the current setpoint of a thermostatic radiator valve, mqtt “set” is used with the target setpoint as payload.
Currently a fixed temperature is set, but question is how to set a dynamic value being a helper “input_number”?
Currently the action is:
  • MQTT Publish
  • Topic: zigbee2mqtt/<IEEE address of the device>/set
  • Payload: {"current_heating_setpoint": "20.5"}
As said, this works fine. But how to set something like
{{ input_number.my_temp_setpoint }}
When this is used in the “Payload Template”, the result is an error “value should be string”.
Also this fails:
{"current_heating_setpoint": {{ input_number.my_temp_setpoint | string }} }
Any hints pls?
Don’t know if you’ve already figured this one out, but this is how my YAML for setting dim level on my bathroom lights when a motion is triggered
service: mqtt.publish
  qos: 0
  retain: false
  topic: zigbee2mqtt/bathroom_lights/set
  payload: "{\"brightness\":{{ states('input_number.dim_bathroom') | int }}}"
Hope it helps! :slight_smile:
I didn’t have a solution yet, but this works great. Thank you!
