Zigbee2Mqtt setup how to
i have a poe zigbee adaptor running. it is currently working great under the normal zigbee integration. but im guessing because its not connected via usb to my server it isnt working. any ideas or do i have to connect it via usb
Are you trying to use ZHA (‘the normal zigbee integration’) and Zigbee2MQTT at the same time ? Won’t work. You need to disable ZHA before trying Zigbee2MQTT
at the time of trying to start it i did have the normal zigbee disabled. i ended up just moving the stick via usb to my server which meant having to move it but whatever. ill try it now with it plugged in as well as zigbee disabled
