Hi Team.
I have a SmartThings plug and in Zigbee2MQTT i see Watts , Amps , Volts but in HA i am only seeing Watts and the On/Off switch. How do i expose Volts and Amps as well?
HA only shows On/Off and Watts
Hi Team.
In the 3 entities not shown , there is Amps and Volts but when i open each i see.
This entity is unavailable.
You give up to quickly my padawan
At the bottom you see Advanced settings
click that and voila: options for enabling it
I actually just seen they are disabled. have enabled them
Click on the entity, then click Advanced and Enable
Ah dont give up to quickly. I found that. Just waiting for them to update hopefully
It will require a restart of Home Assistant
Yep all good now thank you. Still getting to grips with HA, Zigbee2MQTT and now i know it does that i will remember for the future.
Thanks all that replied for the help. much appreciated.
