Zigbee2mqtt: show the networkmap in home assistant
What @Robin said and also post the code for the automation as you have it right now.
no error Robin, start only if i do it manually
is the automation turned on?
yes, is turned on
@dextm80
:neutral_face:
@finity sorry :expressionless:
- id: update_networkmap
  alias: 'Zigbee Map Update'
  hide_entity: true
    platform: time_pattern
    minutes: "/10"
    seconds: 0
    service: zigbee2mqtt_networkmap.update
as far as I can see it should be triggering every 10 minutes.
What are you looking at to tell you when the automation was last ran?
156Z
I’m not sure what that is that you’re looking at.
look here at the last_triggered time instead:
if it’s not there then remove ā€œhide_entity: trueā€ from the automation and check it again.
Your automation is not active. Set the state to on
Thanks! How do i remove milliseconds of update? Now i seen 13.05.04.345432
You can create a template sensor and specify your own format.
Ok, thanks @Robin.
Now i’ve another problem, anyone have this?
no line between coordinator and device
I get that when something in my network is screwed up (zigbee USB stick unpluged, etc), but I don’t see it unless something isnt working right as far as i know.
I’ve also changed to using the edge version of zigbee2mqtt since it seems the network map generation works much better, FWIW.
Forgive me, how can I switch to the edge version ?
Assuming you’ve added https://github.com/danielwelch/hassio-zigbee2mqtt as a repo in the addon store, as that’s how you got Zigbee2MQTT in the first place, there are 2 addons it lets you install. Zigbee2MQTT & Zigbee2MQTT-Edge. Screenshot Example.
Install the edge version, stop the stable version, edit the edge version so it’s config matches, then start the edge version.
The network maps it generate correctly show the network mesh (or more precisely, how the router devices form a mesh), in a way the stable version doesn’t seem to do, at least for me.
Example:
Thanks @Silicon_Avatar, unfortunately I am using Hassbian.
@Robin This is great, thank you.
Any chance to change the font in the map?
i“ve used the following for the footer class.
      color: #212121;
      font-family: Roboto, sans-serif;
      -moz-osx-font-smoothing: grayscale;
      -webkit-font-smoothing: antialiased;
      font-weight: 400;
      font-size: 14px;
I think the font should already be set by zigbee2mqtt when creating the dot string. But not all fonts can be used without problems:
https://github.com/mdaines/viz.js/wiki/Caveats
