Need help please. Recently upgrade my rasberry 4 sd to ssd.
Start to have issues with loading of zigbee2mqtt add on.
Im using a doogle P.
A pop saying : Zigbee2MQTT
The add-on is not running. Do you want to start it now?
when click start on.
Zigbee2MQTT
The add-on seems to not be ready, it might still be starting. Do you want to try again?
Unable to start it,
Theres a warning stating 502 bad gateway,
Zigbee had no issues before migration.
Eventhough unable to open zigbee2mqtt , the device in it can stiill be activated.
My config:
data path
/config/zigbee2mqtt
socat
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
base_topic: zigbee2mqtt
user: mqtt_user
password:XXXX
server: mqtt://192.168.50.195
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7a01161d5cd8ed11baf0746162c613ac-if00-port0
Log will show
[01:58:07] INFO: Preparing to start…
[01:58:08] INFO: Socat not enabled
[01:58:08] INFO: Zigbee Herdsman debug logging enabled
[01:58:10] INFO: Starting Zigbee2MQTT…
READ THIS CAREFULLY
Refusing to start because configuration is not valid, found the following errors:
- MQTT retention requires protocol version 5
If you don’t know how to solve this, read Configuration | Zigbee2MQTT
mine zigbee 2 mqtt version is 1.36.0-1
- Updated Zigbee2MQTT to version [
1.36.0
