Zigbee2MQTT Stopped Working 1/5/2025
@KennethLavrsen: Thank you for the information. I’m trying to configure the triggers without any values, as you suggested, but it’s not working properly, and I’m wondering if I can get your input.
I did review your post titled “Using the new action events in Zigbee2MQTT 2.0”. Where I’m not understanding things is the lines on how to format the conditions. In your examples, it looks like a template with curly brackets around the “trigger.to_state.attributes…” part. I tried to simulate what you did, but the automation throws an error; the yaml is as follows:
alias: Testing Zigbee2MQTT v2
description: ""
triggers:
  - entity_id:
      - event.zigbee_smart_button_action
    trigger: state
    not_from: unavailable
    enabled: true
conditions: []
actions:
  - alias: >-
      If Generic Fan Plug is ON --> turn it OFF; else if it is OFF  --> turn it
      ON
    if:
      - condition: "{{trigger.to_state.attributes.event_type == 'single'}}"
      - condition: state
        entity_id: switch.generic_smart_plug
        state: "on"
        enabled: true
    then:
      - action: switch.turn_off
        metadata: {}
        data: {}
    else:
      - if:
          - condition: state
            state: "off"
            enabled: true
        then:
          - action: switch.turn_on
            metadata: {}
            data: {}
    enabled: true
So, then I tried changing the conditions to states, as follows, but it only works intermittently:
description: ""
triggers:
  - entity_id:
    trigger: state
    enabled: true
conditions: []
actions:
  - alias: >-
      ON
    if:
      - condition: or
        conditions:
          - condition: state
            entity_id: event.zigbee_smart_button_action
            attribute: event_type
            state: single
      - condition: state
        state: "on"
        enabled: true
    then:
        metadata: {}
        data: {}
    else:
      - if:
          - condition: state
            state: single
          - condition: state
            state: "off"
            enabled: true
        then:
            metadata: {}
            data: {}
    enabled: true
