My Zigbee2MQTT has been working great until the latest update.
It seems to just fail connection over and over again.
Zigbee2MQTT Log
info 2022-08-17 15:02:59: Logging to console and directory: '/config/zigbee2mqtt/log/2022-08-17.15-02-59' filename: log.txt
info 2022-08-17 15:02:59: Starting Zigbee2MQTT version 1.27.0 (commit #unknown)
info 2022-08-17 15:02:59: Starting zigbee-herdsman (0.14.46)
info 2022-08-17 15:02:59: zigbee-herdsman started (resumed)
info 2022-08-17 15:02:59: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20220219,"transportrev":2},"type":"zStack3x0"}'
info 2022-08-17 15:03:00: Currently 6 devices are joined:
info 2022-08-17 15:03:00: Front Door (0x00158d0007e59564): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
info 2022-08-17 15:03:00: Back Door (0x00158d0007f84a51): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
info 2022-08-17 15:03:00: Front Door Lock (0x000d6f000f76c53b): YRD226HA2619 - Yale Assure lock (EndDevice)
info 2022-08-17 15:03:00: Front Door Motion Sensor (0x00158d0007752c2c): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
info 2022-08-17 15:03:00: Fridge Door (0x00158d0007f8073a): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
info 2022-08-17 15:03:00: Kitchen Sensor (0x00158d00075a30a1): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
info 2022-08-17 15:03:00: Zigbee: disabling joining new devices.
info 2022-08-17 15:03:00: Connecting to MQTT server at mqtt://172.30.32.1
error 2022-08-17 15:03:00: MQTT failed to connect: Connection refused: Not authorized
error 2022-08-17 15:03:00: Exiting...
info 2022-08-17 15:03:00: Stopping zigbee-herdsman...
info 2022-08-17 15:03:10: Stopped zigbee-herdsman
Mosquitto Log
1660763435: New connection from 172.30.32.1:41221 on port 1883.
1660763435: Client <unknown> disconnected, not authorised.
1660763449: New connection from 172.30.32.2:56460 on port 1883.
1660763449: Client <unknown> closed its connection.
1660763487: New connection from 172.30.32.1:42726 on port 1883.
1660763487: Client <unknown> disconnected, not authorised.
1660763488: New connection from 172.30.32.1:42728 on port 1883.
1660763488: Client <unknown> disconnected, not authorised.
1660763489: New connection from 172.30.32.1:42730 on port 1883.
1660763489: Client <unknown> disconnected, not authorised.
1660763490: New connection from 172.30.32.1:42732 on port 1883.
1660763490: Client <unknown> disconnected, not authorised.
1660763491: New connection from 172.30.32.1:42734 on port 1883.
1660763491: Client <unknown> disconnected, not authorised.
1660763492: New connection from 172.30.32.1:42736 on port 1883.
1660763492: Client <unknown> disconnected, not authorised.
1660763493: New connection from 172.30.32.1:42738 on port 1883.
1660763493: Client <unknown> disconnected, not authorised.
1660763494: New connection from 172.30.32.1:42740 on port 1883.
1660763494: Client <unknown> disconnected, not authorised.
1660763495: New connection from 172.30.32.1:42742 on port 1883.
1660763495: Client <unknown> disconnected, not authorised.
1660763496: New connection from 172.30.32.1:42744 on port 1883.
1660763496: Client <unknown> disconnected, not authorised.
1660763499: New connection from 172.30.32.1:35817 on port 1883.
1660763499: Client <unknown> disconnected, not authorised.
1660763569: New connection from 172.30.32.2:56462 on port 1883.
1660763569: Client <unknown> closed its connection.
1660763619: New connection from 172.30.32.1:35943 on port 1883.
1660763619: Client <unknown> disconnected, not authorised.
1660763689: New connection from 172.30.32.2:56464 on port 1883.
1660763689: Client <unknown> closed its connection.
1660763739: New connection from 172.30.32.1:38335 on port 1883.
1660763739: Client <unknown> disconnected, not authorised.
1660763809: New connection from 172.30.32.2:56466 on port 1883.
1660763809: Client <unknown> closed its connection.
1660763859: New connection from 172.30.32.1:52651 on port 1883.
1660763859: Client <unknown> disconnected, not authorised.
1660763929: New connection from 172.30.32.2:56468 on port 1883.
1660763929: Client <unknown> closed its connection.
1660763979: New connection from 172.30.32.1:49923 on port 1883.
1660763979: Client <unknown> disconnected, not authorised.
1660764049: New connection from 172.30.32.2:56470 on port 1883.
1660764049: Client <unknown> closed its connection.
1660764099: New connection from 172.30.32.1:43491 on port 1883.
1660764099: Client <unknown> disconnected, not authorised.
1660764169: New connection from 172.30.32.2:56472 on port 1883.
1660764169: Client <unknown> closed its connection.
1660764219: New connection from 172.30.32.1:50671 on port 1883.
1660764219: Client <unknown> disconnected, not authorised.
1660764289: New connection from 172.30.32.2:56474 on port 1883.
1660764289: Client <unknown> closed its connection.
1660764339: New connection from 172.30.32.1:53239 on port 1883.
1660764339: Client <unknown> disconnected, not authorised.
1660764409: New connection from 172.30.32.2:56476 on port 1883.
1660764409: Client <unknown> closed its connection.
1660764459: New connection from 172.30.32.1:38245 on port 1883.
1660764459: Client <unknown> disconnected, not authorised.
1660764529: New connection from 172.30.32.2:56478 on port 1883.
Configuration
homeassistant: true
mqtt:
server: mqtt://172.30.32.1
user: notYours
password: itsMine
serial:
port: >-
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ee9a0708f65fec11a2602e5f25bfaa52-if00-port0
frontend:
port: 8099
devices:
"0x00158d0007e59564":
friendly_name: Front Door
temperature_precision: 1
temperature_calibration: -6
"0x00158d0007f84a51":
friendly_name: Back Door
temperature_calibration: -10
"0x000d6f000f76c53b":
friendly_name: Front Door Lock
"0x00158d0007752c2c":
friendly_name: Front Door Motion Sensor
occupancy_timeout: 15
"0x00158d0007f8073a":
friendly_name: Fridge Door
"0x00158d00075a30a1":
friendly_name: Kitchen Sensor
occupancy_timeout: 5
permit_join: false
Any help will be appreciated.
