Zigbee2mqtt stopped working - prevents boot
dear all,
my add-on stopped working. it prevents home assistant from booting.
used to work yesterday - I tried to replace a battery from a PARASOL-sensor and ist started to behave buggy…
as I cannot bring up home assistant anymore, I am stuck with the log in HA observer
any help possible? maybe: how to disable the zigbee2mqtt in some config?
2025-06-14 04:35:52.842 WARNING (MainThread) [supervisor.addons.options] Unknown option ‘serial’ for Zigbee2MQTT (45df7312_zigbee2mqtt)
2025-06-14 04:35:52.842 WARNING (MainThread) [supervisor.addons.options] Option ‘advanced’ does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
2025-06-14 04:36:36.323 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-whisper with version 2.6.0
2025-06-14 04:40:53.533 WARNING (MainThread) [supervisor.addons.options] Unknown option ‘serial’ for Zigbee2MQTT (45df7312_zigbee2mqtt)
2025-06-14 04:40:53.533 WARNING (MainThread) [supervisor.addons.options] Option ‘advanced’ does not exist in the schema for Zigbee2MQTT (45df7312_zigbee2mqtt)
2025-06-14 04:42:21.047 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
Any SSH add-on installed, or the Samba add-on installed?
both - but looks like the server is not loading these add-ons either
Can you attach a keyboard and monitor ?
I finally found out that my installation is working “extremely” slow and constandly reboots - I’ll close this issue for the moment and will open a new incident
thanks!
