Zigbee2MQTT stops, can't start via Watchdog, but starts instantly manually
I am using the SMLIGHT SLZB-06 Zigbee adapter that’s connected over Ethernet. Power is provided via a USB adapter.
The problem is that a few times a week, all my Zigbee network goes offline. The Zigbee2MQTT addon crashes, seemingly due to ECONNRESET. Then, Watchdog tries to restart it, but it can’t seem to find config (Please set a value for the 'data_path' option.). Usually when I notice it(in this case ~24 minutes later), I can just start the Zigbee2MQTT addon in Home Assistant and it boots up nicely. ZLZB-06 itself seemingly did not restart, as its web interface shows (screenshot taken at 17:56, for comparison with logs):
Zigbee2MQTT log:
[2024-11-11 17:00:51] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/Bedroom thermostat', payload '{"child_lock":null,"current_heating_setpoint":22,"deadzone_temperature":null,"heat":"OFF","linkquality":116,"local_temperature":23.5,"local_temperature_calibration":null,"max_temperature_limit":null,"min_temperature_limit":null,"program":null,"running_state":"idle","sensor":null,"system_mode":"heat"}'
[2024-11-11 17:00:51] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/Bedroom thermostat', payload '{"child_lock":null,"current_heating_setpoint":22,"deadzone_temperature":null,"heat":"OFF","linkquality":120,"local_temperature":23.5,"local_temperature_calibration":null,"max_temperature_limit":null,"min_temperature_limit":null,"program":null,"running_state":"idle","sensor":null,"system_mode":"heat"}'
[2024-11-11 17:01:07] error: 	zh:zstack:znp: Socket error Error: read ECONNRESET
[2024-11-11 17:01:07] info: 	zh:zstack:znp: Port closed
[2024-11-11 17:01:07] info: 	zh:zstack:znp: closing
[2024-11-11 17:01:07] error: 	z2m: Adapter disconnected, stopping
[2024-11-11 17:01:07] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/bridge/state', payload '{"state":"offline"}'
[2024-11-11 17:01:07] info: 	z2m: Disconnecting from MQTT server
[2024-11-11 17:01:07] info: 	z2m: Stopping zigbee-herdsman...
[2024-11-11 17:01:07] info: 	z2m: Stopped zigbee-herdsman
[2024-11-11 17:01:07] info: 	z2m: Stopped Zigbee2MQTT
[17:01:09] INFO: Preparing to start...
[17:01:09] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:09] FATAL:
[17:01:09] FATAL: A required add-on configuration option is missing!
[17:01:09] FATAL:
[17:01:09] FATAL: Please set a value for the 'data_path' option.
[17:01:09] FATAL:
[17:01:09] FATAL: If unsure, check the add-on manual for more information.
[17:01:09] FATAL:
[17:01:10] INFO: Preparing to start...
[17:01:10] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:11] FATAL:
[17:01:11] FATAL: A required add-on configuration option is missing!
[17:01:11] FATAL:
[17:01:11] FATAL: Please set a value for the 'data_path' option.
[17:01:11] FATAL:
[17:01:11] FATAL: If unsure, check the add-on manual for more information.
[17:01:11] FATAL:
[17:01:12] INFO: Preparing to start...
[17:01:12] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:12] FATAL:
[17:01:12] FATAL: A required add-on configuration option is missing!
[17:01:12] FATAL:
[17:01:12] FATAL: Please set a value for the 'data_path' option.
[17:01:12] FATAL:
[17:01:12] FATAL: If unsure, check the add-on manual for more information.
[17:01:12] FATAL:
[17:01:14] INFO: Preparing to start...
[17:01:14] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:14] FATAL:
[17:01:14] FATAL: A required add-on configuration option is missing!
[17:01:14] FATAL:
[17:01:14] FATAL: Please set a value for the 'data_path' option.
[17:01:14] FATAL:
[17:01:14] FATAL: If unsure, check the add-on manual for more information.
[17:01:14] FATAL:
[17:01:16] INFO: Preparing to start...
[17:01:16] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:16] FATAL:
[17:01:16] FATAL: A required add-on configuration option is missing!
[17:01:16] FATAL:
[17:01:16] FATAL: Please set a value for the 'data_path' option.
[17:01:16] FATAL:
[17:01:16] FATAL: If unsure, check the add-on manual for more information.
[17:01:16] FATAL:
[17:01:17] INFO: Preparing to start...
[17:01:18] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:18] FATAL:
[17:01:18] FATAL: A required add-on configuration option is missing!
[17:01:18] FATAL:
[17:01:18] FATAL: Please set a value for the 'data_path' option.
[17:01:18] FATAL:
[17:01:18] FATAL: If unsure, check the add-on manual for more information.
[17:01:18] FATAL:
[17:01:19] INFO: Preparing to start...
[17:01:19] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:19] FATAL:
[17:01:19] FATAL: A required add-on configuration option is missing!
[17:01:19] FATAL:
[17:01:19] FATAL: Please set a value for the 'data_path' option.
[17:01:19] FATAL:
[17:01:19] FATAL: If unsure, check the add-on manual for more information.
[17:01:19] FATAL:
[17:01:21] INFO: Preparing to start...
[17:01:21] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:21] FATAL:
[17:01:21] FATAL: A required add-on configuration option is missing!
[17:01:21] FATAL:
[17:01:21] FATAL: Please set a value for the 'data_path' option.
[17:01:21] FATAL:
[17:01:21] FATAL: If unsure, check the add-on manual for more information.
[17:01:21] FATAL:
[17:01:22] INFO: Preparing to start...
[17:01:22] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:22] FATAL:
[17:01:22] FATAL: A required add-on configuration option is missing!
[17:01:22] FATAL:
[17:01:22] FATAL: Please set a value for the 'data_path' option.
[17:01:22] FATAL:
[17:01:22] FATAL: If unsure, check the add-on manual for more information.
[17:01:22] FATAL:
[17:01:24] INFO: Preparing to start...
[17:01:24] ERROR: Got unexpected response from the API: System is not ready with state: setup
[17:01:24] FATAL:
[17:01:24] FATAL: A required add-on configuration option is missing!
[17:01:24] FATAL:
[17:01:24] FATAL: Please set a value for the 'data_path' option.
[17:01:24] FATAL:
[17:01:24] FATAL: If unsure, check the add-on manual for more information.
[17:01:24] FATAL:
[17:25:52] INFO: Preparing to start...
[17:25:52] INFO: Socat enabled
[17:25:52] INFO: Starting socat
Socat startup parameters:
Options:     -d -d
Master:      pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
Slave:       tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
[17:25:52] INFO: Starting socat process ...
2024/11/11 17:25:52 socat[46] N PTY is /dev/pts/0
2024/11/11 17:25:52 socat[46] N listening on AF=10 [0000:0000:0000:0000:0000:0000:0000:0000]:8485
[17:25:52] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-11-11 17:26:00] info: 	z2m: Logging to console, file (filename: log.log)
[2024-11-11 17:26:00] info: 	z2m: Starting Zigbee2MQTT version 1.41.0 (commit #unknown)
[2024-11-11 17:26:00] info: 	z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-11 17:26:01] info: 	zh:zstack:znp: Opening TCP socket with 192.168.1.70:6638
[2024-11-11 17:26:01] info: 	zh:zstack:znp: Socket connected
[2024-11-11 17:26:01] info: 	zh:zstack:znp: Socket ready
[2024-11-11 17:26:01] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-11-11 17:26:02] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-11-11 17:26:02] info: 	z2m: zigbee-herdsman started (resumed)
[2024-11-11 17:26:02] info: 	z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20220219,"transportrev":2},"type":"zStack3x0"}'
[2024-11-11 17:26:02] info: 	z2m: Bathroom Presence (0x70ac08fffe696790): ZY-M100-L - Tuya Ceiling human breathe sensor (Router)
[2024-11-11 17:26:02] info: 	z2m: Bathroom thermostat (0x50325ffffe28b191): BHT-002-GCLZB - Moes Moes BHT series Thermostat (Router)
[2024-11-11 17:26:02] info: 	z2m: Nursery thermostat  (0x50325ffffe4189b4): BHT-002-GCLZB - Moes Moes BHT series Thermostat (Router)
[2024-11-11 17:26:02] info: 	z2m: Bedroom thermostat (0x50325ffffe4181e4): BHT-002-GCLZB - Moes Moes BHT series Thermostat (Router)
[2024-11-11 17:26:02] info: 	z2m: Office thermostat (0x847127fffe1dc065): BHT-002-GCLZB - Moes Moes BHT series Thermostat (Router)
[2024-11-11 17:26:02] info: 	z2m: Bathroom scene switch (0x60a423fffe95146b): TS004F - Tuya Wireless switch with 4 buttons (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Kitchen Light (0xcc86ecfffef3bcb5): TS0601_dimmer_2 - Tuya 2 gang smart dimmer (Router)
[2024-11-11 17:26:02] info: 	z2m: Living room light 2 (0x5c0272fffe229386): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Techroom light (0x60a423fffe305368): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Kitchen light switch (0xa4c138a2c8694b79): ZS-EUB_2gang - Moes Smart light switch - 2 gang (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Living room light (0x60a423fffef8d202): TS0601_dimmer_1_gang_1 - Tuya 1 gang smart dimmer (Router)
[2024-11-11 17:26:02] info: 	z2m: Corridor light (0x60a423fffef8d1fe): TS0601_dimmer_1_gang_1 - Tuya 1 gang smart dimmer (Router)
[2024-11-11 17:26:02] info: 	z2m: Sofi bed button (0xa4c138b31648f836): TS0044 - Tuya Wireless switch with 4 buttons (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Office presence (0x54ef44100064c731): RTCZCGQ11LM - Aqara Presence sensor FP1 (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Nursery floor lamp (0x003c84fffefad2b8): LED2003G10 - IKEA TRADFRI bulb E26/27, white spectrum, globe, opal, 1055/1100/1160 lm (Router)
[2024-11-11 17:26:02] info: 	z2m: Nursery wall button (0x00158d0007e0a18d): WXKG11LM - Aqara Wireless mini switch (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Kitchen wall plug (0xa4c1384a059c5f0d): ZK-EU - Moes Smart wallsocket (with power monitoring) (Router)
[2024-11-11 17:26:02] info: 	z2m: Nursery light (0x60a423fffea643d7): TS0601_dimmer_1_gang_1 - Tuya 1 gang smart dimmer (Router)
[2024-11-11 17:26:02] info: 	z2m: Porch Plug (0xa4c138db00acecb4): A1Z - Nous Smart plug (with power monitoring) (Router)
[2024-11-11 17:26:02] info: 	z2m: Doorbell Chime Plug (0xa4c138f83e80d163): A1Z - Nous Smart plug (with power monitoring) (Router)
[2024-11-11 17:26:02] info: 	z2m: Bathroom temperature (0x00158d000320aa0e): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Bedroom Wall Button (0x00158d0007e4ada6): WXKG11LM - Aqara Wireless mini switch (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Kitchen Rotary Switch (0x385b44fffe36afe5): ERS-10TZBVK-AA - Tuya Smart knob (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Nursery Door (0x00158d0008647903): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Nursery Table Button (0x00158d0007e06d7e): WXKG11LM - Aqara Wireless mini switch (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Nursery Table Vibration (0xa4c138bfbcb67829): TS0210 - Tuya Vibration sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Nursery Window Powerstrip (0x842e14fffefcdc0e): TS0115 - Tuya Multiprise with 4 AC outlets and 2 USB super charging ports (10A or 16A) (Router)
[2024-11-11 17:26:02] info: 	z2m: Fridge Plug (0xa4c138f889aacfa4): A1Z - Nous Smart plug (with power monitoring) (Router)
[2024-11-11 17:26:02] info: 	z2m: Office Window Powerstrip (0x842e14fffefce030): TS0115 - Tuya Multiprise with 4 AC outlets and 2 USB super charging ports (10A or 16A) (Router)
[2024-11-11 17:26:02] info: 	z2m: Office Motion (0x00124b00245c3459): SNZB-03 - SONOFF Motion sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Techroom Motion (0x00124b00245c42c3): SNZB-03 - SONOFF Motion sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Bedroom Bed Button (0x00124b0024ce56bf): SNZB-01 - SONOFF Wireless button (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Bedroom Bed LED (0xa4c138fc2205128c): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
[2024-11-11 17:26:02] info: 	z2m: Bedroom Light (0x60a423fffee5924e): TS0601_dimmer_1_gang_1 - Tuya 1 gang smart dimmer (Router)
[2024-11-11 17:26:02] info: 	z2m: Entryway Button (0x00124b0023973606): SNZB-01 - SONOFF Wireless button (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Kitchen Light Sensor (0x04cf8cdf3c7d2da6): GZCGQ01LM - Xiaomi Mi light sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Kitchen Motion (0x00124b00245d3a1f): SNZB-03 - SONOFF Motion sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Sauna Door (0x00158d0008391766): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Sauna Temperature (0x00158d0006beadb6): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Sauna Light (0xa4c138b97a566f82): TS0001_switch_module - Tuya 1 gang switch module (Router)
[2024-11-11 17:26:02] info: 	z2m: 0x00124b0024452332 (0x00124b0024452332): SNZB-04 - SONOFF Contact sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: A1 Mini Temperature (0x00158d0006beae45): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
[2024-11-11 17:26:02] info: 	z2m: Currently 42 devices are joined.
[2024-11-11 17:26:02] info: 	z2m: Zigbee: disabling joining new devices.
[2024-11-11 17:26:02] info: 	z2m: Connecting to MQTT server at mqtt://192.168.1.25:1883
[2024-11-11 17:26:03] info: 	z2m: Connected to MQTT server
[2024-11-11 17:26:03] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/bridge/state', payload '{"state":"online"}'
[2024-11-11 17:26:04] info: 	z2m: Started frontend on port 8099
[2024-11-11 17:26:05] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/bridge/state', payload '{"state":"online"}'
[2024-11-11 17:26:05] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/Bathroom Presence', payload '{"cli":" ","detection_delay":0,"fading_time":30,"illuminance_lux":3,"linkquality":76,"maximum_range":3.3,"minimum_range":0,"presence":false,"radar_sensitivity":7,"self_test":"check_success","target_distance":0}'
SLZB-06 log:
[07:44:05] ConfigHelper | write config
[07:44:05] ConfigHelper | config saved
[07:44:59] taskZB | New client: 192.168.1.25 id: 0
[17:00:58] taskZB | Client disconnected, id: 0
[17:26:01] taskZB | New client: 192.168.1.25 id: 0
[17:50:01] ConfigHelper | write config
[17:50:01] ConfigHelper | config saved
zigbee2mqtt addon config:
data_path: /config/zigbee2mqtt_eth
socat:
  enabled: true
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://192.168.1.25:1883
  user: hass
  password: xxxxxxxxxx
  base_topic: z2m_eth
serial:
  port: tcp://192.168.1.70:6638
  baudrate: 115200
  adapter: zstack
  disable_led: true
I tried changing a setting on SLZB-06, which requires a restart, and this is how a controlled restart looks from HA’s perspective:
[2024-11-11 17:55:28] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/Nursery thermostat ', payload '{"child_lock":null,"current_heating_setpoint":24,"deadzone_temperature":null,"heat":"OFF","linkquality":98,"local_temperature":23.5,"local_temperature_calibration":null,"max_temperature_limit":null,"min_temperature_limit":null,"preset":"program","preset_mode":"program","program":null,"running_state":"idle","sensor":null,"system_mode":"heat"}'
[2024-11-11 17:56:15] error: 	zh:zstack:znp: Socket error Error: read ECONNRESET
[2024-11-11 17:56:15] info: 	zh:zstack:znp: Port closed
[2024-11-11 17:56:15] info: 	zh:zstack:znp: closing
[2024-11-11 17:56:15] error: 	z2m: Adapter disconnected, stopping
[2024-11-11 17:56:15] info: 	z2m:mqtt: MQTT publish: topic 'z2m_eth/bridge/state', payload '{"state":"offline"}'
[2024-11-11 17:56:15] info: 	z2m: Disconnecting from MQTT server
[2024-11-11 17:56:15] info: 	z2m: Stopping zigbee-herdsman...
[2024-11-11 17:56:15] info: 	z2m: Stopped zigbee-herdsman
[2024-11-11 17:56:15] info: 	z2m: Stopped Zigbee2MQTT
[18:00:54] INFO: Preparing to start... <-- Z2M "Start" manually pressed
I’d be thankful for any thoughts on where else to look or what to try.
I have the same issue
Did you fix it?
Nope. Still having to start it from time to time
There are a bunch of people having the same issue: SLZB-06 freezing every few days · Koenkk/zigbee2mqtt · Discussion #21157 · GitHub
Thanks for directing me there! I flashed v2.6.8.dev16 firmware on the SLZB through the web interface, as the suggested v2.6.8.dev14. Let’s see if that works.
Well to me it seems to work to deactivate the Home Assistant integration alone. Someone suggested in the thread, that you could manually add the SLZB in the integration with the IP-Adress rather than the local link. I didn’t do that, because I thought I don’t really need the Integration itself. If I want to check something I go to the WebUI of the SLZB anyways.
