Zigbee2Mqtt strange behavior
Greetings everyone,
I have some issue with my Z2M implementation. As you can see from the screenshot below I have lqi of 0 for some of the devices.
When I generate map of the devices I can see much bigger values.
What can be the reason? I have issues with one of the devices from time to time (Moes switch) and with Xiaomi WSDCGQ11LM no matter that for the Xiaomi temp & Hum I`ve configure router to enhance the signal.
Can you please suggest what can cause the different LQI in device and map view?
Can you please suggest how to make reliable connection to each device (More routers- what kind you will suggest)?
Regards!!
