I have a strange issue in one of my packages.
Background:
The switch is a Tradfri E1603 control outlet connected through Zigbee2mqtt.
Both the Zigbee2mqqt controller and the application are updated to the latest versions recently.
In my package I have this:
## Media center operations, sensor (Tradfri via Zigbee2MQTT)
- platform: "mqtt"
state_topic: "zigbee2mqtt/tradfri_media_switch"
availability_topic: "zigbee2mqtt/bridge/state"
unit_of_measurement: "-"
value_template: "{{ value_json.linkquality }}"
switch:
## Media center operations, switch (Tradfri via Zigbee2MQTT)
# used for powering up all media devices
- platform: "mqtt"
payload_off: "OFF"
payload_on: "ON"
value_template: "{{ value_json.state }}"
command_topic: "zigbee2mqtt/tradfri_media_switch/set"
The script looks like this:
script:
## Script for setting up media when main media switch is still off
media_from_off:
alias: Media start als media switch uit
sequence:
- service: timer.start
entity_id: timer.media_center_delay
- service: homeassistant.turn_on
entity_id: switch.tradfri_media_switch
- delay: '00:00:30'
When the script runs, the switch is not set.
Any tips where the error is (if any)?
Notes:
Manually changing the switch works flawless.
A second tradfri E1603 works perfect in automations and scripts.
UPDATE (20190517): Apperantly the automations and scrips in the bases are working fine. However Hass sometimes does not update the device. I also see this with the second Tradfri. Some times it does not switch and Hass also keeps showing the previous state.
Thanks for the help
Ralph
