Zigbee2MQTT - Sync Keypad and Alarm Control Panel States
Thanks. I have this keypad Universal Electronics Inc XHK1-UE control via MQTT | Zigbee2MQTT
It does have support for : disarm , arm_day_zones , arm_night_zones , arm_all_zones , invalid_code , not_ready , already_disarmed
Please check what action is triggered on the button that is not working for you. You can use the Zigbee2MQTT log to do so.
MQTT publish: topic 'zigbee2mqtt/Alarm Keypad', payload '{"action":"arm_night_zones","action_code":"1234","action_transaction":39,"action_zone":23,"battery":100,"battery_low":true,"contact":true,"linkquality":90,"occupancy":true,"presence":null,"tamper":false,"temperature":21,"voltage":5300}'
That is the line from the log
Okay, then you’re out of luck with this blueprint, unfortunately. The keypads I use can only switch between two armed modes, not three.
Of course, if you want to, you can work your way in and add the third mode to the blueprint. Contributions are always welcome.
Sounds great. The blue print does work great for me, just the one button doesn’t work using it. I will try to figure out what to change to make it work and then share it. Thanks so much, this is what I always wanted and a big reason I switched from deconz.
Working great with my Technicolor XHK1-TC (Technicolor XHK1-TC control via MQTT | Zigbee2MQTT).
Modified the blueprint since it was missing arm_night_zones.
blueprint:
  name: Alarmo Keypad Sync with nightmode
  description: Keypad sync with Alarmo added nightmode
  domain: automation
  input:
    state_topic:
      name: MQTT State Topic of your Zigbee2MQTT Keypad
      description: "The State Topic is composed of your Zigbee2MQTT base_topic (see your Z2M Addon Configuration) and the Friendly Name of your keypad in Z2M. Example: zigbee2mqtt/Keypad"
      selector:
        text:
    set_topic:
      name: MQTT Set Topic of your Zigbee2MQTT Keypad
      description: "This is the same as your State Topic, with the addition of /set. Example: zigbee2mqtt/Keypad/set"
      selector:
        text:
    entity:
      description: "An alarm control panel entity from alarmo."
      selector:
        entity:
          domain: alarm_control_panel
          integration: alarmo
  - platform: state
    entity_id: !input entity
    to: disarmed
  - platform: state
    to: armed_home
  - platform: state
    to: armed_night
  - platform: state
    to: armed_away
  - platform: state
    to: arming
  - platform: state
    to: pending
  - platform: state
    to: triggered
  - platform: mqtt
    topic: !input state_topic
  - platform: event
    event_type: alarmo_failed_to_arm
  - platform: event
    event_type: alarmo_command_success
condition: []
  - choose:
      - conditions:
          - condition: trigger
          - service: mqtt.publish
            data_template:
              topic: !input set_topic
              payload: |-
                  "arm_mode":
                    "mode": "disarm"
      - conditions:
            data_template:
              payload: |-
                  "arm_mode":
                    "mode": "arm_day_zones"
      - conditions:
            data_template:
              payload: |-
                  "arm_mode":
                    "mode": "arm_night_zones"
      - conditions:
            data_template:
              payload: |-
                  "arm_mode":
                    "mode": "arm_all_zones"
      - conditions:
            data_template:
              payload: |-
                  "arm_mode":
                    "mode": "exit_delay"
      - conditions:
            data_template:
              payload: |-
                  "arm_mode":
                    "mode": "entry_delay"
      - conditions:
            data_template:
              payload: |-
                  "arm_mode":
                    "mode": "in_alarm"
      - conditions:
          - choose:
              - conditions:
                  - condition: template
                    value_template: '{{ trigger.payload_json.action == "disarm"  }}'
                  - service: alarmo.disarm
                      code: "{{ trigger.payload_json.action_code }}"
                      context_id: "{{ trigger.payload_json.action_transaction }}"
              - conditions:
                    value_template: '{{ trigger.payload_json.action == "arm_all_zones"  }}'
                  - service: alarmo.arm
                      mode: away
              - conditions:
                    value_template: '{{ trigger.payload_json.action == "arm_day_zones"  }}'
                      mode: home
              - conditions:
                    value_template: '{{ trigger.payload_json.action == "arm_night_zones"  }}'
                      mode: night
      - conditions:
          - choose:
              - conditions:
                    value_template: "{{ trigger.event.data.reason == 'invalid_code' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
                            "transaction": {{ trigger.event.data.context_id }},
                            "mode": "invalid_code"
              - conditions:
                    value_template: "{{ trigger.event.data.reason == 'open_sensors' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
                            "mode": "not_ready"
              - conditions:
                    value_template: "{{ trigger.event.data.reason == 'not_allowed' }}"
                    value_template: "{{ trigger.event.data.command|lower == 'disarm' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
                            "mode": "already_disarmed"
      - conditions:
          - choose:
              - conditions:
                    value_template: "{{ trigger.event.data.action == 'arm' }}"
                    value_template: "{{ trigger.event.data.context_id != null }}"
                    value_template: "{{ trigger.event.data.mode == 'away' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
              - conditions:
                    value_template: "{{ trigger.event.data.mode == 'home' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
              - conditions:
                    value_template: "{{ trigger.event.data.mode == 'night' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
              - conditions:
                    value_template: "{{ trigger.event.data.action == 'disarm' }}"
                    data_template:
                      payload: |-
                          "arm_mode":
                            "mode": "disarm"
mode: parallel
max: 10
Hi Paolo.
I have the same Develco Keypad and I’ve managed to get it working with this blueprint.
When armed and disarmed the keypad gives feedback with a ‘Beep’. If I have a arm delay, the keypad is not beeping during the countdown. It this the same for you?
Did you get this to work with more than one code?
If so, can you share how you did this?
Thanks :slight_smile:
I ended up using alarmo and then I made these automations to control the keypad.
I use two keypad so this can be done much simpler.
Awesome!
Thanks for your help :slight_smile:
Have you figured it out? I am at the same spot right now. Everything works except the arm_night_zones.
if you are a moron like me scratching your head thinking you have it setup perfectly. please check for upper/lower case naming you have set!
my friendly name was set to keypad and in the blueprint i had zigbee2mqqt/Keypad
renamed zigbee friendly name to Keypad and suprise suprise it now works!
Can I ask how you got this to work? The keypad paired fine. It seems to communicate with the automation in that it triggers it, and it seems to get responses back. If I arm the alarm, the keypad gets the message and glows red. If I run the actions in the blueprint by hand, it arms or disarms the alarm (using alarmo). But the keypad will never arm or disarm the alarm. The trace always looks the same (Option 6 executed). It seems like it is very nearly working, but some detail is wrong. Any help appreciated.
UPDATE: OK, I figured out that I needed to add another 4-digit code to Alarmo for the keypad. I made it the same as the keypad code, so not sure if it because they are the same, or because it needed to be 4 digits, or because it just needed to be a new slot. But now it works. alarm_night_zones is not working, so might try the modifications of @Tykan to the blueprint.
Great work @AndrejDelany ! Thank you for sharing.
I tried @Tykan 's modification, but it lacked some of the features of the original, so I modded the original instead. All I did was add the night arming feature available on both Alarmo and the Xfinity XHK1-UE keypad. Using this blueprint, you could easily program this button on the keypad to do some other function on your alarm panel, like arm vacation. It is a trivial change to @AndrejDelany 's original blueprint, so I will just add it here.
blueprint:
  name: PIN-Keypads for Zigbee2MQTT including Xfinity XHK1-UE
  description: This Blueprint allows the synchronisation of an alarm control panel
    with a Zigbee2MQTT keypad. This means that the status of the alarm control panel
    is transmitted to the keypad and vice versa.
  domain: automation
  input:
    z2m_keypad_path:
      description: 'The State Topic is composed of your Zigbee2MQTT base_topic (see
        Example: zigbee2mqtt/Keypad'
    z2m_keypad_path_set:
      description: 'This is the same as your State Topic, with the addition of /set.
        Example: zigbee2mqtt/Keypad/set'
    pin:
      description: 'The valid pin code to be accepted as correct by your alarm system.
        Example: 1234'
    control_panel:
      description: 'An alarm control panel. Example: https://www.home-assistant.io/integrations/manual'
      default: []
      selector:
        entity:
          domain:
          - alarm_control_panel
          multiple: false
    action_arming:
      description: An action to be performed when the alarm panel changes to the arming
        state.
      default: []
      selector:
        action: {}
    action_armed_home:
      name: Action Armed Home
      description: An action to be performed when the alarm panel changes to the armed
        home state.
      default: []
      selector:
        action: {}
    action_armed_night:
      name: Action Armed Night
        away state.
      default: []
      selector:
        action: {}
    action_armed_away:
      name: Action Armed Away
        away state.
      default: []
      selector:
        action: {}
    action_disarmed:
      description: An action to be performed when the alarm panel changes to the disarmed
        state.
      default: []
      selector:
        action: {}
    action_pending:
      description: An action to be performed when the alarm panel changes to the pending
        state.
      default: []
      selector:
        action: {}
    action_panic:
      description: An action to be performed when the panic / SOS button of the keypad
        is pressed.
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zigbee2mqtt-sync-keypad-and-with-alarm-control-panel-states/345311
variables:
  pin_var: !input pin
- platform: state
  entity_id: !input control_panel
  to: arming
- platform: state
  to: armed_home
- platform: state
  to: armed_night
- platform: state
  to: disarmed
- platform: state
  to: armed_away
- platform: state
  to: pending
- platform: mqtt
  topic: !input z2m_keypad_path
condition: []
- choose:
  - conditions:
    - choose:
      - conditions:
        - condition: state
          state: armed_home
          attribute: next_state
          data_template:
            topic: !input z2m_keypad_path_set
            payload: "{\n \"arm_mode\": \n  {\n   \"mode\": \"arm_day_zones\"\n  }\n}"
      - conditions:
        - condition: state
          state: armed_night
          data_template:
            payload: "{\n \"arm_mode\": \n  {\n   \"mode\": \"arm_night_zones\"\n  }\n}"
      - conditions:
        - condition: state
          state: armed_away
          data_template:
            payload: "{\n \"arm_mode\": \n  {\n   \"mode\": \"exit_delay\"\n  }\n}"
      default: []
    - choose:
      default: !input action_arming
  - conditions:
      data_template:
        payload: "{\n \"arm_mode\": \n  {\n   \"mode\": \"arm_all_zones\"\n  }\n}"
    - choose:
      default: !input action_armed_away
  - conditions:
      data_template:
        payload: "{\n \"arm_mode\": \n  {\n    \"mode\": \"disarm\"\n  }\n}"
    - choose:
      default: !input action_disarmed
  - conditions:
      data_template:
    - choose:
      default: !input action_armed_home
  - conditions:
      data_template:
    - choose:
      default: !input action_armed_night
  - conditions:
    - choose:
      default: !input action_pending
  - conditions:
    - choose:
      - conditions:
          value_template: '{{ trigger.payload_json.action_transaction != null and
            trigger.payload_json.action_code == pin_var }}'
          data_template:
            payload: "{\n \"arm_mode\": \n  {\n    \"transaction\": \"{{ trigger.payload_json.action_transaction
              }}\",\n    \"mode\": \"{{ trigger.payload_json.action }}\"\n  }\n}"
    - choose:
      - conditions:
          value_template: '{{ trigger.payload_json.action_code == pin_var and trigger.payload_json.action
        - service: alarm_control_panel.alarm_arm_away
            code: !input pin
      - conditions:
        - service: alarm_control_panel.alarm_arm_night
            code: !input pin
      - conditions:
        - service: alarm_control_panel.alarm_arm_home
            code: !input pin
      - conditions:
            == "disarm" }}'
        - service: alarm_control_panel.alarm_disarm
            code: !input pin
      - conditions:
          value_template: '{{ trigger.payload_json.action == "panic" }}'
        - choose:
          default: !input action_panic
      - conditions:
          value_template: '{{ trigger.payload_json.action_code != pin_var and trigger.payload_json.action_code
            | int(-1) != -1 }}'
          data_template:
              }}\",\n   \"mode\": \"invalid_code\"\n  }\n}"
      - conditions:
          value_template: '{{ trigger.payload_json.action == None }}'
        - choose:
          - conditions:
            - condition: state
              state: armed_away
              data_template:
                  \ }\n}"
          - conditions:
            - condition: state
              state: armed_home
              data_template:
                  \ }\n}"
          - conditions:
            - condition: state
              state: armed_night
              data_template:
                  \ }\n}"
          - conditions:
            - condition: state
              state: disarmed
              data_template:
          - conditions:
            - condition: state
              state: arming
            - condition: state
              state: armed_home
              data_template:
                  \ }\n}"
          - conditions:
            - condition: state
              state: arming
            - condition: state
              state: armed_night
              data_template:
                  \ }\n}"
          - conditions:
            - condition: state
              state: arming
            - condition: state
              state: armed_away
              data_template:
                  \ }\n}"
      default: []
  default: []
mode: parallel
max: 10
I’m having trouble importing this and keep getting
No valid blueprint found in the topic. Blueprint syntax blocks need to be marked as YAML or no syntax
any suggestions?
I have tried editing it as an automation directly but struggling as my yaml skills are rather limited.
Did you check in the blueprints/automation/AndrejDelany folder to see if you have the yaml file there? You might need to restart HA.
Good luck.
Wasn’t there so I created it and the blueprint is now available, haven’t got it working exactly as I wanted but at least I now have something to work with.
Many thanks for helping me out :+1:
And obviously many thanks to @AndrejDelany for the blueprint :+1:
Is there any way to extend this Blueprint to support additional usage of codes - i.e. 8888 = turn off the lights, 7777 = open my garage door
I love this idea! Will have a look into it, but don’t expect it to happen right now as I’m on vacation.
Thanks - Enjoy!
