Yes, you are right. I updated the blueprint accordingly.
Has anyone used the Linkind ZS130000078 keypad with rechargeable 3.7V rechargeable batteries type 16340 and can tell, if they work as replacement for the CR123A batteries?
Hello
Thank you for this blueprint. Is there a way to use different pin codes?
I use a keypad with a rfid sensor. Each rfid tag returns a different pin code through zigbee2mqtt (for example +2FA9ED04). Each member of the family has a different tag and of course a different pin code. I can add each of them in alarmo but the blueprint only works with the main pin code.
Iāve looked a little bit at your blueprint but there is only one āpin:ā option and of course I canāt duplicate it. Iāve tried to put several pin codes separated with a, or a ; but it wonāt work.
Thanks - unfortunately I will have to wait till next week to test it out.
Thanks for the command Pimseb, Iām also looking for this option.
In principle, it is possible to adapt the blueprint in this scenario. For this, several PIN variables would have to be introduced under different names. In the queries you can then check if one of the PINs is correct. For example:
trigger.payload_json.action_code == pin_var or trigger.payload_json.action_code == second_pin_var
I set the āAction Panic, An action to be performed when the panic / SOS button of the keypad is pressed.ā to āTrigger Alarmoā but nothing happens. I can set HOME, AWAY, arm and disarmā¦ Only a yellow light blinks on my frient KEPZB-110 keypad?
Would this be possible no matter what keypad is used? The way I read the Develco KEYZB-110 docs, it seems that it validates the PIN-code on the device. I believe others does as well - they expect to be armed with a PIN code, and disarmed later with the same PIN code. i Is it possible to set a list of different PIN codes to the different alarm panels? I assume a work around would be to disarm the panel from HA using a set code, and have separate checking of valid PINs.
Have anyone tested if the different alarm panels can be armed without a PIN code? I donāt want to have to enter a PIN to arm the alarm using the keypad.
If the PIN code is evaluated directly on the device, then you can only use this PIN. But I donāt know if there are devices that do so. If they do, you would have to set the PIN on the device itself first, which is not the case with the keypads I know.
Ah, Ok, then I probably have misread the develco keypad user manual. Iāll give it a shot!
I have added the entry_delay to the blueprint and it works really well with my keypad (the Xfinity XHK1-UE, Universal Electronics Inc XHK1-UE control via MQTT | Zigbee2MQTT)
blueprint:
name: PIN-Keypads for Zigbee2MQTT - with entry delay
description: This Blueprint allows the synchronisation of an alarm control panel
with a Zigbee2MQTT keypad. This means that the status of the alarm control panel
is transmitted to the keypad and vice versa.
domain: automation
input:
z2m_keypad_path:
name: MQTT State Topic of your Zigbee2MQTT Keypad
description: 'The State Topic is composed of your Zigbee2MQTT base_topic (see
your Z2M Addon Configuration) and the Friendly Name of your keypad in Z2M.
Example: zigbee2mqtt/Keypad'
z2m_keypad_path_set:
name: MQTT Set Topic of your Zigbee2MQTT Keypad
description: 'This is the same as your State Topic, with the addition of /set.
Example: zigbee2mqtt/Keypad/set'
pin:
description: 'The valid pin code to be accepted as correct by your alarm system.
Example: 1234'
control_panel:
description: 'An alarm control panel. Example: https://www.home-assistant.io/integrations/manual'
default: []
selector:
entity:
domain: alarm_control_panel
action_arming:
description: An action to be performed when the alarm panel changes to the arming
state.
default: []
selector:
action: {}
action_armed_home:
name: Action Armed Home
description: An action to be performed when the alarm panel changes to the armed
home state.
default: []
selector:
action: {}
action_armed_away:
name: Action Armed Away
away state.
default: []
selector:
action: {}
action_armed_night:
name: Action Armed Night
night state.
default: []
selector:
action: {}
action_disarmed:
description: An action to be performed when the alarm panel changes to the disarmed
state.
default: []
selector:
action: {}
action_pending:
description: An action to be performed when the alarm panel changes to the pending
state.
default: []
selector:
action: {}
action_panic:
description: An action to be performed when the panic / SOS button of the keypad
is pressed.
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/zigbee2mqtt-sync-keypad-and-with-alarm-control-panel-states/345311
variables:
pin_var: !input 'pin'
- platform: state
entity_id: !input 'control_panel'
to: arming
- platform: state
to: disarmed
- platform: state
to: armed_home
- platform: state
to: armed_away
- platform: state
to: armed_night
- platform: state
to: pending
- platform: mqtt
topic: !input 'z2m_keypad_path'
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- choose:
- conditions:
- condition: state
state: armed_home
attribute: next_state
sequence:
- service: mqtt.publish
topic: !input 'z2m_keypad_path_set'
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"arm_day_zones\"\n }\n}"
- conditions:
- condition: state
state: armed_night
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"arm_night_zones\"\n }\n}"
- conditions:
- condition: state
state: armed_away
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"exit_delay\"\n }\n}"
default: []
- choose:
default: !input 'action_arming'
- conditions:
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"arm_all_zones\"\n }\n}"
- choose:
default: !input 'action_armed_away'
- conditions:
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"disarm\"\n }\n}"
- choose:
default: !input 'action_disarmed'
- conditions:
sequence:
- choose:
default: !input 'action_armed_home'
- conditions:
sequence:
- choose:
default: !input 'action_armed_night'
- conditions:
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"entry_delay\"\n }\n}"
- choose:
default: !input 'action_pending'
- conditions:
sequence:
- choose:
- conditions:
- condition: template
value_template: '{{ trigger.payload_json.action_transaction != null and
trigger.payload_json.action_code == pin_var }}'
sequence:
payload: "{\n \"arm_mode\": \n {\n \"transaction\": \"{{ trigger.payload_json.action_transaction\
\ }}\",\n \"mode\": \"{{ trigger.payload_json.action }}\"\n }\n}"
- choose:
- conditions:
value_template: '{{ trigger.payload_json.action_code == pin_var and trigger.payload_json.action
== "arm_all_zones" }}'
sequence:
- service: alarm_control_panel.alarm_arm_away
code: !input 'pin'
- conditions:
== "arm_night_zones" }}'
sequence:
- service: alarm_control_panel.alarm_arm_night
code: !input 'pin'
- conditions:
== "arm_day_zones" }}'
sequence:
- service: alarm_control_panel.alarm_arm_home
code: !input 'pin'
- conditions:
== "disarm" }}'
sequence:
- service: alarm_control_panel.alarm_disarm
code: !input 'pin'
- conditions:
value_template: '{{ trigger.payload_json.action == "panic" }}'
sequence:
- choose:
default: !input 'action_panic'
- conditions:
value_template: '{{ trigger.payload_json.action_code != pin_var and trigger.payload_json.action_code
| int(-1) != -1 }}'
sequence:
\ }}\",\n \"mode\": \"invalid_code\"\n }\n}"
- conditions:
value_template: '{{ trigger.payload_json.action == None }}'
sequence:
- choose:
- conditions:
- condition: state
state: armed_home
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"arm_day_zones\"\n\
\ }\n}"
- conditions:
- condition: state
state: armed_away
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"arm_all_zones\"\n\
\ }\n}"
- conditions:
- condition: state
state: armed_night
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"arm_night_zones\"\n\
\ }\n}"
- conditions:
- condition: state
state: disarmed
sequence:
payload: "{\n \"arm_mode\": \n {\n \"mode\": \"disarm\"\n\
\ }\n}"
- conditions:
- condition: state
state: arming
- condition: state
state: armed_home
sequence:
\ }\n}"
- conditions:
- condition: state
state: arming
- condition: state
state: armed_away
sequence:
\ }\n}"
- conditions:
- condition: state
state: arming
- condition: state
state: armed_night
sequence:
\ }\n}"
default: []
default: []
mode: parallel
max: 10
Hello Everyone,
I am new to Home Assistant and Alarmo however for the past week I have been trying to sync my Xfinity XHK1-UE keypad to my alarmo and Iām about 80% there.
I have downloaded alarmo and I have installed this blueprint on this page. The keypad is working for Home and Away set modes and accepting my set pin code, but the night mode doesnāt work/set with my default pin code. Any ideas?
Please could someone help me.
Kind regards
M
Hello together and many thanks for the great Blueprint. Bit I have on question, what is right way to use the RFID Tag. What do I have to write on the tag or what do I have to enter where in Alarmo, unfortunately I havenāt understood it yet. I have the Frient Keypad KEPZB-110
Thanks AndrejDelany for the Blueprint, everything works well on my end ! Would it be possible to add a toggle to input / or not the pincode when arming the alarm ? Adding fields for other action_code to support RFID badges would be also a great idea as they are just added in the payload
If this means, that you want to activate the alarm without typing in the pin, this is not possible. My keypad only sends a zigbee signal if the pin code is entered first.
Actually I donāt own a keypad with rfid support, so implementing this is quite difficult for me. But community contributions by the community are always welcome!
Thanks for the quick reply !
It is not the case for my āFrient KEPZB-110ā, any button press sends a Zigbee event, even an empty one sometimes.
Iām currently trying to edit your blueprint to accomodate my needs. Iāll let you know if I succeed in doing so !
EDIT : Iāve sucessefully added support to enable/disable pin codes when arming the alarm and also support for multiple RFIDs to be used as ācodesā. Iāll try to use it normaly to see if any bugs pops-up and will share the blueprint then.
Hi is there any way to get this working with Hive Keypad & ZHA ?
As this blueprint is heavily coupled to zigbee2mqtt. It would require a complete rewrite to make this work with ZHA.
