Hello everyone,
I’m trying to code this wonderful work from bluprint to nodered to implement my alarm with keypad.
I’m using ALARMO and Develco KEYZB-110
Would anyone know how to help me?
After updating Home Assistant to 2025.1 and Z2M to 2.0, the blueprint no longer worked correctly for me. I have found a fix that resolves this. I would post this above - but only if others also have the problem with the current Home Assistant Version 2025.1 and Zigbee2MQTT 2.0. How does it look for you? Is the blueprint still working?
after moving to z2m 2.0, it stopped working. Reason is probably that the actions have changed in z2m to HA
I just updated the blueprint in the first post to fix the problem. Would be happy for some feedback, if it works ![]()
I’ve just updated to HA 2025.1.2 and z2m 2.0
In z2m, in the ‘status’ tab of the keyboard I still have the ‘actions’ :
Can you tell me (or anyone else) if this is the case for you too ?
For my Linkind Keypad it’s different.
"ac_status": false,
"battery": 8,
"battery_defect": false,
"battery_low": true,
"last_seen": "2025-01-07T00:21:35+01:00",
"linkquality": 69,
"occupancy": false,
"restore_reports": true,
"smoke": false,
"supervision_reports": true,
"tamper": false,
"test": false,
"trouble": false,
"voltage": 2500
ok thanks for the information ![]()
Using the Frient Keypad. Do anyone get feedback to the keypad, such as LED indicators when arming/disarming, and countdown noise?
Hi everyone,
I’m using the blueprint with my Zigbee keypad. The integration works, but I noticed that the blueprint has an open “Pincode” text field where the valid PIN must be entered (example: 1234).
This makes the PIN value:
- Visible in the Home Assistant UI
- Stored in plaintext in the automation/blueprint config
- Potentially included in backups or screenshots
Since I already use Alarmo for my alarm system (which has its own secure PIN handling), I’d prefer not to store the code again in the blueprint.
My questions:
- Is there a way to hide or mask this field in the UI (like password mode)?
- Can I reference a secret (
!secret) or a masked input_text helper instead of typing the raw PIN? - Or should I completely bypass the blueprint and just forward keypad events (with the raw
pin_codefrom MQTT) directly to Alarmo for validation?
I’m mainly looking for best practices on handling PINs securely here, so they aren’t exposed in plain text.
Thanks for any suggestions!
