I recently started with homeassistant, falling amidst the zwavejs change and using two instances of HA I decided to move to mqtt versions of zwave and zigbee. I had it working at some stage but it stopped and couldn’t get it working whatever I tried. I had my old rp3 box revived this have it all working again, all updated to latest version and I restored a backup to my rpi 4… All is working except for zigbee2mqtt. I see same errors as before. Broker connects and disconnects and zigbee saying can’t connect to mqtt.
Zigbee2MQTT:warn 2021-03-06 11:34:29: permit_join
set to true
in configuration.yaml.
Zigbee2MQTT:warn 2021-03-06 11:34:29: Allowing new devices to join.
Zigbee2MQTT:warn 2021-03-06 11:34:29: Set permit_join
to false
once you joined all devices.
Zigbee2MQTT:info 2021-03-06 11:34:29: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2021-03-06 11:34:29: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2021-03-06 11:34:29: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:debug 2021-03-06 11:34:29: Using MQTT login with username: addons
Zigbee2MQTT:error 2021-03-06 11:34:39: Not connected to MQTT server!
Zigbee2MQTT:error 2021-03-06 11:34:49: Not connected to MQTT server!
Where does the addons use comes from?? i created this user but no luck
on the broker
1615027504: Socket error on client , disconnecting.
1615027505: New connection from 172.30.33.5 on port 1883.
1615027505: Socket error on client , disconnecting.
1615027506: New connection from 172.30.33.5 on port 1883.
1615027506: Socket error on client , disconnecting
The broker log is full with these messages
ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquitto
ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message=‘Invalid response status’, url=URL(‘http://172.30.33.3:8099/socket.io/?EIO=4&transport=websocket&sid=LKmPNl_qFcAMYUXRAAAA’)
In the supervisor log I see these errors the last one I did also have on the rpi3 however all mqtt stuff was working.
Another thing I see on the rpi4 is ERROR: Can’t setup Home Assistant service mqtt, after restarting the broker. If I do the same on the RPI3 just runs fine.
I am really out of options, a working system on an rpi3 so not a config issue, restored to an rpi4 where everything works except for zigbee2mqtt??? any suggestions or having similar problems with mqtt on this platform?
