I have several devices under deconz.
If I want to try Zigbee2MQTT, can I try to disable deconz and then install Zigbee2MQTT?
So in case I have problems with Zigbee2MQTT, can I go back and re-enable deconz?
Then if I want to migrate to Zigbee2MQTT what can I do? Just uninstall deconz?
Never tried,
If you make a backup you might be able to reinstall deconz, however I’m unsure if the devices will need re-pairing as they get a new network.
If you want to go for Z2M, just uninstall deconz, reboot and follow the install instructions for Z2M. Remember not to install ZHA, it will auto detect during re-start…
Hi Robban,
Using deconz I’m not able to adjust sensitivity of motion sensor (Aqara Motion sensor P1) because not present . Then i don’t see the lux entity of sensor.
