Zigbee2mqtt Tradfri motion sensor not reporting motion state changes (missing keys)
I’ve been running a zigbee network for years successfully with zigbee2mqtt (via a CC25XX) And today I paired three new IKEA devices (whereas most of my network is cheap Gledopto lights and Xiaomi sensors).
I added:
  • 1x IKEA Tradfri signal repeater (E1746)
  • 2x IKEA Tradfri motion sensors (E1745)
Problem
Everything appears to pair successfully but the motion sensors do not publish state changes to MQTT.
Successful pairing in the logs
Zigbee2MQTT:info  2020-12-13 06:17:40: MQTT publish: topic 'zigbee2mqtt/switch_2', payload '{"battery":100,"linkquality":94,"voltage":3022}'
Zigbee2MQTT:debug 2020-12-13 06:17:53: Received Zigbee message from 'hydroponics_switch', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:17:58: Device 'motion_sensor_1' announced itself
Zigbee2MQTT:info  2020-12-13 06:17:58: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"motion_sensor_1"},"type":"device_announced"}'
Zigbee2MQTT:debug 2020-12-13 06:18:00: Received Zigbee message from 'rotel_switch', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:19: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"modelId":"TRADFRI motion sensor"}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:19: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"modelId":"TRADFRI motion sensor"}'
Zigbee2MQTT:debug 2020-12-13 06:18:21: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"IKEA of Sweden"}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:21: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"manufacturerName":"IKEA of Sweden"}'
Zigbee2MQTT:debug 2020-12-13 06:18:23: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"powerSource":3}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:23: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"powerSource":3}'
Zigbee2MQTT:debug 2020-12-13 06:18:25: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:25: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"zclVersion":3}'
Zigbee2MQTT:debug 2020-12-13 06:18:27: Received Zigbee message from 'schitt_switch', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:27: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"appVersion":32}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:27: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"appVersion":32}'
Zigbee2MQTT:debug 2020-12-13 06:18:29: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"stackVersion":98}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:29: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"stackVersion":98}'
Zigbee2MQTT:debug 2020-12-13 06:18:31: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"hwVersion":1}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:31: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"hwVersion":1}'
Zigbee2MQTT:debug 2020-12-13 06:18:33: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20190308"}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:33: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"dateCode":"20190308"}'
Zigbee2MQTT:debug 2020-12-13 06:18:35: Received Zigbee message from 'motion_sensor_1', type 'readResponse', cluster 'genBasic', data '{"swBuildId":"2.0.022"}' from endpoint 1 with groupID 0
Zigbee2MQTT:debug 2020-12-13 06:18:35: No converter available for 'E1525/E1745' with cluster 'genBasic' and type 'readResponse' and data '{"swBuildId":"2.0.022"}'
Zigbee2MQTT:info  2020-12-13 06:18:35: Successfully interviewed 'motion_sensor_1', device has successfully been paired
Zigbee2MQTT:info  2020-12-13 06:18:35: Device 'motion_sensor_1' is supported, identified as: IKEA TRADFRI motion sensor (E1525/E1745)
Zigbee2MQTT:info  2020-12-13 06:18:35: Configuring 'motion_sensor_1'
Zigbee2MQTT:info  2020-12-13 06:18:35: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"TRADFRI motion sensor","friendly_name":"motion_sensor_1","model":"E1525/E1745","supported":true,"vendor":"IKEA"},"type":"pairing"}'
Zigbee2MQTT:info  2020-12-13 06:18:39: Successfully configured 'motion_sensor_1'
States.json
{...,"0xbc33acfffe0d7c8a":{"update_available":false},"0xbc33acfffe0d919d":{"update_available":false},"0xbc33acfffe5f8827":{"linkquality":60,"update_available":false}}
As you can see, zigbee2mqtt finds and rrecognises the devices, enough to check for updates, but it is not recording any messages from the devices.
Database entries
{"id":18,"type":"EndDevice","ieeeAddr":"0xbc33acfffe0d919d","nwkAddr":8216,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery","modelId":"TRADFRI motion sensor","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":2128,"inClusterList":[0,1,3,9,32,4096,64636],"outClusterList":[3,4,6,8,25,4096],"clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI motion sensor","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20190308","swBuildId":"2.0.022"}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cc29","endpointID":1}],"meta":{}}},"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20190308","swBuildId":"2.0.022","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1607840475784}
{"id":19,"type":"EndDevice","ieeeAddr":"0xbc33acfffe0d7c8a","nwkAddr":11375,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery","modelId":"TRADFRI motion sensor","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":2128,"inClusterList":[0,1,3,9,32,4096,64636],"outClusterList":[3,4,6,8,25,4096],"clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI motion sensor","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":3,"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20190308","swBuildId":"2.0.022"}}},"binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cc29","endpointID":1}],"meta":{}}},"appVersion":32,"stackVersion":98,"hwVersion":1,"dateCode":"20190308","swBuildId":"2.0.022","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1},"lastSeen":1607840391779}
{"id":20,"type":"Router","ieeeAddr":"0xbc33acfffe5f8827","nwkAddr":44523,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Mains (single phase)","modelId":"TRADFRI Signal Repeater","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":8,"inClusterList":[0,3,9,2821,4096],"outClusterList":[25,32,4096],"clusters":{"genBasic":{"attributes":{"modelId":"TRADFRI Signal Repeater","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":3,"appVersion":33,"stackVersion":98,"hwVersion":1,"dateCode":"20190311","swBuildId":"2.2.005"}}},"binds":[{"cluster":0,"type":"endpoint","deviceIeeeAddress":"0x00124b0018e1cc29","endpointID":1}],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[33],"outClusterList":[33],"clusters":{},"binds":[],"meta":{}}},"appVersion":33,"stackVersion":98,"hwVersion":1,"dateCode":"20190311","swBuildId":"2.2.005","zclVersion":3,"interviewCompleted":true,"meta":{"configured":2},"lastSeen":1607834998536}
Sometimes motion sensors report LQI
Once in a while I can see state changes for LQI on the motion sensors, but all other JSON keys / values are missing from the payload:
It feels like I’m the only person on the internet facing this issue. Any ideas what I could be missing?
The motion sensors will not work if the firmware on your cc25XX is too old. They need the latest firmware.
Do you perhaps know the lowest supported version? My CC is on 20190308 and facing the same problem. I don’t have the hardware to update, so would have to order it… Thanks in advance :slight_smile:
I think you need 20190619. If you have a Pi you can update it that way.
Thanks Francis. It’s been ages since I flashed it - that’s probably it.
Used this as an excuse to upgrade to a Zig-ah-Zig-ah.
