I’m having this issue with Z2M since I began using HA. In short, triggers in MQTT devices disappear after a day:
If I do the triggers, they appear again:
But then it disappear again after a day. This is a big problem because when the trigger is done and disappeared, it won’t trigger the automation, which leads to having to push 2 times.
I have this error appearing at HA startup:
2023-06-19 22:03:48.274 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Plafond' failed to setup triggers and has been disabled: Unknown device '3c2afad960c6c9e25177be2f848a8417'
2023-06-19 22:03:48.296 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Cuisine' failed to setup triggers and has been disabled: Unknown device '3c2afad960c6c9e25177be2f848a8417'
2023-06-19 22:03:48.298 ERROR (MainThread) [homeassistant.components.automation] Automation with alias 'Lampe' failed to setup triggers and has been disabled: Unknown device '3c2afad960c6c9e25177be2f848a8417'
I discussed with Z2M team who told me it would be because HA is not retaining them.
What could be wrong ? I found no information on this issue.
Any answer, any help is welcome.
Have a great day.
