This is a blueprint for the Tuya 4-button Scene Switch TS004F.
For now, in order to have TS004F connected successfully with your ZigBee network, you need to own the original Tuya ZigBee Gateway, just initially.
1. Pair with Tuya Gateway with the original app (I use Smart Life), hold lower left button until all lights flash
2. After connecting in Smart Life, choose scene switcher when asked, not dimmer (not sure if that matters, it’s the choice I made)
3. Allow new devices in Zigbee2MQTT
4. Remove device in the app (Delete and wipe)
Device should immidiately interview successfully with Z2M. You will know if it was successful if the battery level is reported correctly, push some buttons to refresh the data. If your device doesn’t report battery level, then it didn’t interview correctly and I have no more hints for you, try again.
EDIT: You might actually have to hold the lower left button until the device goes into pairing mode as the last step, it might not actually connect with Z2M on its own. I am afraid to test it all again, you have to try it yourself. The device NAS-AB02B0 needs exactly the same procedure to work with Z2M correctly and it doesn’t need to be forced into pairing mode in the end, this one may have to.
Then and ONLY THEN will this blueprint work. Unfortunately as it stands right now, I was unable to get any double click or button hold actions, only single clicks. This tremendously sucks, but at least you get 4 actions that actually work.
Code below is based entirely off of Stringer’s blueprint, all credit goes to him.
blueprint:
name: Zigbee2MQTT - Tuya 4-Button Scene Switch TS004F
description: Automate your Tuya 4-Button Scene Switch TS004F via Zigbee2MQTT.
domain: automation
input:
switch:
name: Tuya 4-Button Scene Switch TS004F
description: Tuya 4-Button Scene Switch to use
selector:
entity:
integration: mqtt
domain: sensor
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 (lower-left) single press
default: []
selector:
action: {}
button_two_short_press:
name: Single Press - Button 2
description: Action to run on button 2 (lower-right) single press
default: []
selector:
action: {}
button_three_short_press:
name: Single Press - Button 3
description: Action to run on button 3 (upper-right) single press
default: []
selector:
action: {}
button_four_short_press:
name: Single Press - Button 4
description: Action to run on button 4 (upper-left) single press
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input 'switch'
attribute: action
- variables:
command: '{{ trigger.to_state.state }}'
- choose:
- conditions:
- '{{ command == ''off'' }}'
sequence: !input 'button_one_short_press'
- conditions:
- '{{ command == ''brightness_step_down'' }}'
sequence: !input 'button_two_short_press'
- conditions:
- '{{ command == ''brightness_step_up'' }}'
sequence: !input 'button_three_short_press'
- conditions:
- '{{ command == ''on'' }}'
sequence: !input 'button_four_short_press'
