I’m facing errors after updating to Home Assistant 2022.10. Automations are no longer available.
Errors are:
2022-10-06 02:20:50.003 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: automation
2022-10-06 02:20:50.015 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: automation')
Logger: homeassistant.setup
Source: components/device_automation/trigger.py:69
First occurred: 3:05:04 AM (1 occurrences)
Last logged: 3:05:04 AM
Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 67, in async_validate_trigger_config
return await platform.async_validate_trigger_config(hass, config)
File "/usr/src/homeassistant/homeassistant/components/hue/device_trigger.py", line 44, in async_validate_trigger_config
raise InvalidDeviceAutomationConfig(f"Device ID {device_id} is not valid")
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Device ID c162359ed7df93641d0122b65a393798 is not valid
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 246, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 690, in _async_process_config
await async_validate_config_item(hass, raw_config),
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 80, in async_validate_config_item
config[CONF_TRIGGER] = await async_validate_trigger_config(
File "/usr/src/homeassistant/homeassistant/helpers/trigger.py", line 100, in async_validate_trigger_config
conf = await platform.async_validate_trigger_config(hass, conf)
File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 69, in async_validate_trigger_config
raise InvalidDeviceAutomationConfig("invalid trigger configuration") from err
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: invalid trigger configuration
Therefore i’ve performed a restore to HA 2022.9.7.
But now i can no longer open the zigbee2mqtt UI in the sidebar
How to solve this issue?
