I’m a bit confused about the documentation regarding setting device specific configuration.
To be exact, i seem unable to set the temperature_calibration for the Xiaomi device.
But after a restart and blowing on it to trigger a change, It will report the higher temp from my breath and then settle back down to the original temp without the calibration applied…
Also tried just adding 1 but still the same values.
Now the documentation mentions this part:
# Optional: see 'Device specific configuration' below
device_options: {}
But either i’m overlooking this but i can find no example how to use this.
Edit: Even more confused, it seems the calibration line gets deleted after a restart
O wonderfull, it happens whenever i go and look at the device in zigbee2mqtt.
