@Koenkk has this device been added recently and is the homeassistant addon of zigbee2mqtt not updated yet?
Or do I have to add this device manually?
I tried following the instructions under “support new devices” on zigbee2mqtt.io. But I got stuck because in the home assistant addon I dont have the option to generate an external definition. Or am I missing something?
I solved it, I installed the dev version of zigbee2mqtt and rebuild the whole network from scratch (good fun…). The controller got recognised correctly this time
I’ve had that same model supported and working for the past 2 years.
Worst case scenario, yours had a different Zigbee Manufacturer ID (extremely common with Tuya) and you just needed to wait 3 more weeks for that to be released into the main branch.
