Any help would be appreciated for this error, I have gone back to a previous backup but would like to upgrade to latest version.
I have just tried upgrading Zibee2MQTT to 2.0.0-1, once done my Sonoff dongle is no longer recognised. I have followed the suggestions in the log at Z2M 2.0.0: `USB adapter discovery error (No valid USB adapter found)` · Koenkk/zigbee2mqtt · Discussion #24364 · GitHub and added these lines in my configuration.yaml
serial:
port: >-
/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
adapter: zstack
homeassistant_legacy_entity_attributes: false
homeassistant_legacy_triggers: false
legacy_api: false
legacy_availability_payload: false
legacy: false
In the adapter config I have added the line
adapter: zstack and also tried ezsp
I am getting errors in the log like:
[16:09:25] INFO: Preparing to start...
[16:09:25] INFO: Socat not enabled
[16:09:26] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2025-01-04 16:09:27] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 adapter: zstack
[2025-01-04 16:09:32] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 adapter: zstack
[2025-01-04 16:09:42] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 adapter: zstack
[2025-01-04 16:09:57] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 adapter: zstack
[2025-01-04 16:09:57] error: z2m: Error while starting zigbee-herdsman
[2025-01-04 16:09:57] error: z2m: Failed to start zigbee-herdsman
[2025-01-04 16:09:57] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-04 16:09:57] error: z2m: Exiting...
[2025-01-04 16:09:57] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:364:19)
at Driver.startup (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:186:13)
at EZSPAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:145:16)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:142:13)
at start (/app/index.js:161:5)
Or
z2m: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 adapter: zstack
Your Sonoff dongle uses hardware from Silicon Labs so your adapter option should be ember, not zstack (which is for a different version of the Sonoff dongle).
[2025-01-05 10:14:56] error: z2m: Error while starting zigbee-herdsman
[2025-01-05 10:14:56] error: z2m: Failed to start zigbee
[2025-01-05 10:14:56] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2025-01-05 10:14:56] error: z2m: Exiting...
[2025-01-05 10:14:57] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
Your device ID is not complete, it should have a serial number in it.
Check under Setttings/System/Hardware/All Hardware
ttyUSB# (ZBDongle-P) or ttyACM# (ZBDongle-E)
ZBDongle-P = zstack
ZBDongle-E = ember (or ezsp for older firmware)
This is one of mine (with xxxxxx for certain parts of the serial):
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f0e8552af91bef11bf08a4d9xxxxxx-if00-port0
I have a Sonoff Dongle Plus with the TI chip which uses zstack. The device’s name does not contain “Silicon Labs” because that’s a different company making a different chip and uses ember (or the deprecated ezsp).
In another topic, a user bought a Sonoff model E dongle but received a model P. They didn’t know they received a different model until they checked the model name printed on the back of the device.
Whenever you have a moment, I would appreciate it if you could check the model name printed on your dongle and confirm it does NOT end with “-P”.
Let us know what’s printed because it’s odd that a model E can work with the zstack protocol which is designed for completely different hardware (the model P).
[2025-05-04 01:31:12] error: z2m: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_12bd00f3d273ef11af12e21e313510fd-if00-port0
It seems that my dongle has just vanished from my Home Assistant hardware, because I can’t see it anymore at Settings > Hardware > All hardware.
And just to add, it was working normally a few days ago.
But in my case, I have model specified correctly and still got the error. For some reason, the dongle USB port just vanish from “Settings > Hardware > all hardware” list.
It was working until few days ago. I’ve just updated HA and Z2M.
I have the latest release of HA.
My config for Z2M is
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt: {}
serial:
port: >-
adapter: zstack
