Zigbee2MQTT update releases
I’ve been waiting for zigbee2mqtt update (i’m on 1.18.1-1) for having support to new IKEA lamp (LED1935C3) because i’ve been unable to support it although followed all instructions for non-supported devices.
Anyone knows the interval of update releases in hassio add-on of zigbee2mqtt? Or any “trick” for supporting this bulb? (i’ve posted previously this post: Zigbee2MQTT error after adding unsupported device: "Error: Cannot find module 'zigbee-herdsman-converters/lib/extend'").
Thanks.
Pedro.
The current version of the addon is 1.21.1. Have you added the new addon repository: https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
The addon has been moved to a new repository.
Thank you for your reply. So there were changes to the repositoire? … i installed it and now i have two " Home Assistant Add-on: Zigbee2mqtt" but what is “installed” is the old one. I must migrate configuration manually? and stop one and start the other one?
Thanks again.
Pedro.
Answer to my question: https://github.com/zigbee2mqtt/hassio-zigbee2mqtt/issues/52#issuecomment-792873888
Pedro.
