“Doesn’t work” doesn’t give enough information. What does the log say? Is the interview being started and does it then fail?
Try checking issues here https://github.com/danielwelch/hassio-zigbee2mqtt/issues
Also upgrade to 1.14.4.2 as that also includes more updates to changelog and readme
log level: debug.
Zigbee: allowing new devices to join. message.
When I try to rejoin a device nothing happens. Not any output in log. I tried multiple.
New devices joining works fine.
Device is: xiaomi aqara temperature humidity sensor
I updated to 1.14.4.2 no improvement
To be clear: are you expecting your xiaomi device to rejoin without going to the pairing process again? Because that isn’t going to happen after you deleted all files like you said a couple of posts ago.
Nope. By joining I mean the pairing process.
Okay. I found the Xiaomi Temp & Humidity sensor finicky to pair because they go to sleep real fast. To pair, press the button a few seconds until the blue light blinks. Then every second or so press the button quickly again to keep the sensor awake and watch the log. It’s hard to get the timing right, so you will have to try a few times.
