I updated to zigbee2mqtt 1.14.4.1 and now I can’ t get my config correct in JSON.
I got the error message:
Failed to save addon configuration, not a valid value for dictionary value @ data[‘options’].
I don’t understand what the problem is. So I try to fallback to de default. Only that is in YAML and the zigbee2mqtt documentation doesn’t also provide a working working example. what a mess.
So can someone please provide a working json example of zigbee2mqtt to get things working again.
Is there a other option to go back a version of zigbee2mqtt then a global homeassistant restore?
i managed to get zigbee2mqtt to get started again. Only I can’t (re)join any devices. zigbee2mqqt found zigbee router but joining any other device doesn’t work. There a no error log messages .
Those are the right ones, but if they are correct then you shouldn’t need to rejoin any devices as they should all be already paired with those details
Is this important?
Line in my log file:
./run.sh: line 17: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
I’m out of options. I complete reinstalled zigbee2mqtt. I manually remove all the zigbee2mqqt data that is left after removing. and reinstalled it. And it still doesn’t work.
