Cannot setup zigbee coordinator (electrolama zzh) on tcp (virtualhere or ser2net).
Running HA supervised on Debian VM from synology. The reason why I’m trying to use tcp is the virtual machine manager keeps randomly unmounting the USB key (a conbee II) which is unacceptable plus the zzh does not work through VMs.
Here is the important bits of my config
(using virtualhere)
serial:
port: 'tcp://192.168.0.30:17570'
advanced:
rtscts: false
socat:
enabled: false
I get
Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
I’ve tried the z2m config found here
where socat is not mentionnend so I left it disabled
(using ser2net)
serial:
port: 'tcp://192.168.0.30:20108'
advanced:
rtscts: false
socat:
enabled: false
here is the result :
2021-03-24T12:13:18.668Z zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.0.30:20108
2021-03-24T12:13:18.681Z zigbee-herdsman:adapter:zStack:znp:log Socket connected
2021-03-24T12:13:18.683Z zigbee-herdsman:adapter:zStack:znp:log Socket ready
2021-03-24T12:13:18.685Z zigbee-herdsman:adapter:zStack:znp:log Writing skip bootloader payload
2021-03-24T12:13:18.686Z zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
2021-03-24T12:13:18.700Z zigbee-herdsman:adapter:zStack:znp:log Port closed
2021-03-24T12:13:19.693Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2021-03-24T12:13:19.697Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2021-03-24T12:13:25.705Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2021-03-24T12:13:25.708Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2021-03-24T12:13:31.715Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2021-03-24T12:13:31.717Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
Zigbee2MQTT:error 2021-03-24 13:13:37: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-03-24 13:13:37: Failed to start zigbee
Zigbee2MQTT:error 2021-03-24 13:13:37: Exiting...
Zigbee2MQTT:error 2021-03-24 13:13:37: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
at Generator.throw (<anonymous>)
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
I’ve also tried this config
(using virtualhere)
serial:
port: /dev/ttyZ2M
advanced:
rtscts: false
socat:
enabled: true
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777,end-close'
slave: 'tcp:192.168.0.30:7575,ignoreeof'
restartdelay: 1
initialdelay: 1
options: '-d -d'
Zigbee2MQTT:error 2021-03-24 15:17:29: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyZ2M'
Socat startup parameters:
Options: -d -d
Master: pty,raw,echo=0,link=/dev/ttyZ2M,mode=777,end-close
Slave: tcp:192.168.0.30:17570,ignoreeof
[15:17:30] INFO: Starting socat process ...
2021/03/24 15:17:30 socat[477] N PTY is /dev/pts/2
2021/03/24 15:17:30 socat[477] E unlink("/dev/ttyZ2M"): Read-only file system
2021/03/24 15:17:30 socat[477] N exit(1)
I’m pulling my hair out… Nothing works
Anyone has a suggestion ?
