Hi All,
I have been scratching my head around trying to upgrade to the new zigbee2mqtt. When I first upgraded some of my devices broke, particularly around the devices I have done a custom configuration.
I have found it is related to the
legacy_availability_payload: false
When this is set during the upgrade or I set it manually before upgrading the same devices break.
I have some thermostats that only control heating that are configured like below. The attributes that are set in this configuration don’t work post change.
I looked here MQTT HVAC but I couldn’t find the missing piece.
Wonder if anyone out there has any ideas?
climate:
- name: "master_bedroom_thermostat_heat"
unique_id: "0x000d6f000ad9a2ff_climate_zigbee2mqtt"
availability_topic: "zigbee2mqtt/bridge/state"
min_temp: "13"
max_temp: "25"
modes:
- "off"
- "heat"
mode_state_topic: "zigbee2mqtt/master_bedroom_thermostat_heat"
mode_state_template: "{{ value_json.system_mode }}"
mode_command_topic: "zigbee2mqtt/master_bedroom_thermostat_heat/set/system_mode"
current_temperature_topic: "zigbee2mqtt/master_bedroom_thermostat_heat"
current_temperature_template: "{{ value_json.local_temperature }}"
temperature_state_topic: "zigbee2mqtt/master_bedroom_thermostat_heat"
temperature_state_template: "{{ value_json.occupied_heating_setpoint }}"
temperature_command_topic: "zigbee2mqtt/master_bedroom_thermostat_heat/set/occupied_heating_setpoint"
temp_step: 0.5
action_topic: "zigbee2mqtt/master_bedroom_thermostat_heat"
action_template: "{% set values = {'idle':'off','heat':'heating'} %}{{ values[value_json.running_state] | default('heating', true) }}"
