I’ve some crash with Zigbee2mqtt, and zigbee2mqtt don’t start.
Infos :
Zigbee2mqtt 1.35.3-1
Mosquitto broker 6.4.0
Core 2024.2.2
Supervisor 2024.02.0
OS : 11.5
Frontend 202402027.1
Raspberry Pi 3
rpi3-64
Clé : SONOFF ZigBee 3.0 USB Dongle Plus, EFR32MG21
Config :
Zigbee2mqtt
Mosquitto Broker
Logs :
Mosquitto
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[10:40:53] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[10:41:20] INFO: Starting NGINX for authentication handling...
2024-02-22 10:41:25: mosquitto version 2.0.18 starting
2024-02-22 10:41:25: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-02-22 10:41:25: Loading plugin: /usr/share/mosquitto/go-auth.so
[10:41:24] INFO: Starting mosquitto MQTT broker...
2024-02-22 10:41:25: Warning: Mosquitto should not be run as root/administrator.
2024-02-22 10:41:25: ├── Username/password checking enabled.
2024-02-22 10:41:25: ├── TLS-PSK checking enabled.
2024-02-22 10:41:25: └── Extended authentication not enabled.
2024-02-22 10:41:25: Opening ipv4 listen socket on port 1883.
2024-02-22 10:41:25: Opening ipv6 listen socket on port 1883.
2024-02-22 10:41:25: Opening websockets listen socket on port 1884.
2024-02-22 10:41:25: mosquitto version 2.0.18 running
2024-02-22 10:41:34: New connection from 127.0.0.1:53728 on port 1883.
2024-02-22 10:41:34: Client <unknown> disconnected due to protocol error.
[10:42:05] INFO: Successfully send discovery information to Home Assistant.
2024-02-22 10:42:07: New connection from x.x.x.2:57542 on port 1883.
2024-02-22 10:42:08: New client connected from x.x.x.2:57542 as mqttjs_3235ee8e (p2, c1, k60, u'addons').
[10:42:19] INFO: Successfully send service information to the Supervisor.
2024-02-22 10:42:24: New connection from x.x.x.1:42745 on port 1883.
2024-02-22 10:42:24: New client connected from x.x.x.1:42745 as 3VeiOYo0O7R4iUd6ZUysTg (p2, c1, k60, u'mqtt').
2024-02-22 10:42:32: New connection from x.x.x.2:42092 on port 1883.
2024-02-22 10:42:32: Client <unknown> closed its connection.
2024-02-22 10:44:32: New connection from x.x.x.2:52844 on port 1883.
2024-02-22 10:44:33: Client <unknown> closed its connection.
2024-02-22 10:46:33: New connection from x.x.x.2:33834 on port 1883.
2024-02-22 10:46:34: Client <unknown> closed its connection.
2024-02-22 10:48:34: New connection from x.x.x.2:42172 on port 1883.
2024-02-22 10:48:34: Client <unknown> closed its connection.
2024-02-22 10:50:35: New connection from x.x.x.2:42584 on port 1883.
2024-02-22 10:50:35: Client <unknown> closed its connection.
2024-02-22 10:52:35: New connection from x.x.x.2:49350 on port 1883.
2024-02-22 10:52:35: Client <unknown> closed its connection.
2024-02-22 10:54:36: New connection from x.x.x.2:54262 on port 1883.
2024-02-22 10:54:36: Client <unknown> closed its connection.
2024-02-22 10:56:36: New connection from x.x.x.2:50354 on port 1883.
2024-02-22 10:56:37: Client <unknown> closed its connection.
2024-02-22 10:56:51: Client mqttjs_3235ee8e closed its connection.
2024-02-22 10:58:22: New connection from x.x.x.2:38456 on port 1883.
2024-02-22 10:58:26: New client connected from x.x.x.2:38456 as mqttjs_56520819 (p2, c1, k60, u'addons').
2024-02-22 10:58:39: New connection from x.x.x.2:38346 on port 1883.
2024-02-22 10:58:39: Client <unknown> closed its connection.
2024-02-22 10:58:43: Client mqttjs_56520819 closed its connection.
2024-02-22 11:00:13: New connection from x.x.x.2:48010 on port 1883.
2024-02-22 11:00:19: New client connected from x.x.x.2:48010 as mqttjs_40d3b4ae (p2, c1, k60, u'addons').
2024-02-22 11:00:41: New connection from x.x.x.2:40772 on port 1883.
2024-02-22 11:00:41: Client <unknown> closed its connection.
2024-02-22 11:01:10: Client mqttjs_40d3b4ae disconnected.
Zigbee2mqtt
vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","object_id":"détecteur_ouverture_porte_baie_vitrée_battery","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0xa4c1387421845932/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","object_id":"détecteur_ouverture_porte_baie_vitrée_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c1387421845932/tamper/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"tamper","object_id":"détecteur_ouverture_porte_baie_vitrée_tamper","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_tamper_zigbee2mqtt","value_template":"{{ value_json.tamper }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0xa4c1387421845932/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"détecteur_ouverture_porte_baie_vitrée_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"radiateur_masterbedroom_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/energy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"energy","enabled_by_default":true,"object_id":"radiateur_masterbedroom_energy","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{ value_json.energy }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"name":"Pilot wire mode","object_id":"radiateur_masterbedroom_pilot_wire_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/select/0x90395efffe2763c2/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Radiateur Masterbedroom/set/pilot_wire_mode","device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"name":"Pilot wire mode","object_id":"radiateur_masterbedroom_pilot_wire_mode","options":["comfort","eco","frost_protection","off","comfort_-1","comfort_-2"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"radiateur_masterbedroom_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"radiateur_masterbedroom_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0x90395efffe2763c2/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"radiateur_masterbedroom_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/update/0x90395efffe2763c2/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/Radiateur Masterbedroom","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Radiateur Masterbedroom","name":null,"object_id":"radiateur_masterbedroom","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x90395efffe2763c2\"}","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"radiateur_chambre_invité_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/energy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"energy","enabled_by_default":true,"object_id":"radiateur_chambre_invité_energy","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{ value_json.energy }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"name":"Pilot wire mode","object_id":"radiateur_chambre_invité_pilot_wire_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/select/0x90395efffe4b1c01/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Radiateur chambre invité/set/pilot_wire_mode","device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"name":"Pilot wire mode","object_id":"radiateur_chambre_invité_pilot_wire_mode","options":["comfort","eco","frost_protection","off","comfort_-1","comfort_-2"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"radiateur_chambre_invité_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"radiateur_chambre_invité_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/binary_sensor/0x90395efffe4b1c01/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"radiateur_chambre_invité_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/update/0x90395efffe4b1c01/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/Radiateur chambre invité","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Radiateur chambre invité","name":null,"object_id":"radiateur_chambre_invité","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x90395efffe4b1c01\"}","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Température salon', payload '{"air_quality":"good","battery":100,"device_temperature":17,"display_unit":"ppb_celsius","humidity":67.15,"linkquality":208,"power_outage_count":21,"temperature":17.76,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":141,"voltage":3056}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Détecteur ouverture porte baie vitrée', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":124,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Radiateur Masterbedroom', payload '{"energy":0.01,"linkquality":236,"pilot_wire_mode":"off","power":0,"state":"ON","update":{"installed_version":66564,"latest_version":66561,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Radiateur chambre invité', payload '{"energy":0.02,"linkquality":212,"pilot_wire_mode":"frost_protection","power":0,"state":"OFF","update":{"installed_version":768,"latest_version":768,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info 2024-02-22 11:05:49: Zigbee2MQTT started!
Supervisor
24-02-22 11:01:21 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 11:01:22 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:01:33 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:01:34 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 11:03:28 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 11:03:28 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 11:03:28 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:03:37 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:03:43 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:03:44 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 11:05:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:05:22 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:05:26 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
